Diamond This forums is for discussing the user-created Diamond plugin for SageTV. |
DO NOT USE 7.1.3 AND DIAMOND!!
Title says it all stay away from the new beta for many reasons some diamond related and some metadata related. Until all this gets hashed out diamond will not support anything later than 7.1.2.
cheers pluckyhd Last edited by PLUCKYHD; 03-10-2011 at 10:09 AM. |
I think that most folks regularly on here are "in the know," but the other sticky on this forum is titled "You Must be using the latest Sagetv BETA". This, of course, could lead to confusion or at least more questions, especially from those who don't check in here every day.
Might you either combine the stickies or retitle the older one so that there is less potential confusion? Perhaps "Sage versions supported by Diamond" where you'd list both those that are supported as well as those that are known not to work. Just thinking out loud. Matt
Server: Ubuntu 16.04 running Sage for Linux v9 |
Tom
HD-PVR w/v1.5.6 drivers / Hauppauge IR blaster / FiOS Extreme HD / Motorola QIP6200 / SPDIF+720p Fixed Output on HP Media Center 8400F (Phenom 9500 QuadCore 2.2GHz, nVidia GeForce 8500 GT) via Olevia 247TFHD/Onyko TX-SR606/Harmony 550/HP MediaSmart EX490 WHS w/12TB Plex Media Server v0.9.9.5 on HP Touchsmart Envy 23 d16qd Sonos Play:3, Connect / SimpleTV v2 / Roku 2 XS+Plex / iPhone 5 / iPad 2 |
You need to reread
So if you had already upgraded to 7.1.3 prior to this notice, how do you get back to 7.1.2? Just install 7.1.2? Or have to uninstall sage, and reinstall?
Sage Server: HP ProLiant N40L MicroServer, AMD Turion II Neo N40L 1.5GHz Dual Core, 8GB Ram, WHS2011 64bit, Sage 7.1.9 WHS, HDHR (1 QAM, 1 OTA), HDHR Prime 3CC, HD-PVR for copy-once movie channels HTPC Client:Intel DH61AG, Intel G620 cpu, 8GB ram, Intel 80GB SSD, 4GB RamDisk holding Sage/Java/TMT5 Sage Client:Sage HD-200 Extender |
Wait it out. You should have a backup of your wiz bin if you want to uninstall and revert back.
Remove
So is it alright to update to 7.1.4 for use with diamond ?
It still will work from what I know but there will be some/allot of things that are broken as there where some stv changes.
Diamond Fanart | dstanley | Diamond | 7 | 03-20-2011 06:35 PM |
Diamond and SageMyMovies | emotionnotion | Diamond | 1 | 03-09-2011 11:18 AM |
FAQ for Diamond | jusjoken | Diamond | 0 | 03-05-2011 06:56 AM |
Diamond Sub-theme: Diamond MKANET Mod | mkanet | SageTV v7 Customizations | 2 | 02-21-2011 05:18 AM |
Diamond Multimedia 30% off sale | GKenny | The SageTV Community | 6 | 09-21-2005 05:17 PM |
