Diamond This forums is for discussing the user-created Diamond plugin for SageTV. |
Diamond Compatibility with the 'Restart Sage from Setup Menu' Plugin
I used the 'Restart Sage from Setup Menu' plugin from skiingwiz prior to installing (and falling in love with) Diamond. I was wondering if there was a way to get the 'Restart SageTV' option back into the Setup menu using inbuilt functionality of Diamond, the new ADM plugin, or some other manual mechanism. Any guidance would be appreciated.
Thanks, Brian |
k |
I don't think diamond changed the structure of the menus at all, so it SHOULD still work with diamond AND the restart server UI Mod.
![]() I have it showing on my setup menu with just Diamond installed, although with Diamond you will have to scroll down to the bottom of the second level as it's not visible until you get to the bottom of the items (Diamond adds a scolling menu mod to allow more items than normal). (See attached and notice that you can't see the configuration wizard item as it's scrolled off the top of the second level menu for setup.) It doesn't show in the Setup menu with ADM enabled for me so you will have to follow the ADM wiki and add the item manually. Jeremy |
One of my UI pet peeves is a scrollable list with no indication that it is scrollable... ;-) Really needs at LEAST a down pointing arrow if there is more down there...
![]() Probably didn't add it there as we don't add items to that list and the main reason we added was to accommodate the custom Diamond movie views. * Update - Scroll Bar in secondary Setup Menu Added for next release (sorry no eta...) J Last edited by jorton; 07-23-2011 at 06:37 PM. |
I tried changing to use specific Widget and tried both BBJDL-207 [Restart SageTV] and BBJDL-216 [ConfirmPanel] without luck but did get it to work if I set it to BBJDL-208 [IsSageTVServerEnabled()] but then you do not get the confirmation screen. It will just do the Restart. Jorton/Jeremy - even though you have the Button there, does it actually do anything for you along with the confirmation screen? If so, which Widget is it using? FYI - this testing was with Sage in non-service mode |
Jusjoken replied in the ADM thread.
So if you have ADM, have advanced options on, for action type, specify widget and use BBJDL-215 |
Good to hear, jusjoken's pretty speedy with the updates
![]() Just for clarification my original screen shot was of the restart plugin installed on just Diamond, no ADM, and it was working correctly. If I enabled ADM it was not there. I didin't actually get a chance to try adding the item manually to ADM. Cheers, J |
Tags |
diamond |
STVi: Restart Sage from Setup Menu | skiingwiz | SageTV v7 Customizations | 14 | 03-26-2017 02:38 PM |
Plugin: Scrolling Setup on Main Menu | tmiranda | SageTV Studio | 0 | 01-15-2011 08:37 AM |
Plugin installation and restart | michaeldjcox | SageTV v7 Customizations | 8 | 07-23-2010 10:54 AM |
Scheduled Windows Restart / Reboot (Shutdown -r) and Sage doesn't restart | dealsdyker | SageTV Software | 8 | 03-09-2007 04:24 PM |
Where can I find the menu title theme (Main Menu, Program Guide, Setup Menu, etc) | mkanet | SageTV Studio | 5 | 11-11-2005 04:55 AM |
