Old 02-16-2020, 01:54 PM
cdw2000 cdw2000 is offline
.properties files in recordings folder?
Hello,
I've recently transitioned to using OpenDCT from SageDCT for recording from my HDHomerun Prime. This all occurred at the same time as I transitioned to Windows 10. I have since noticed that for every newly recorded TV show .ts file, there is now a corresponding .properties file in my TV Recordings folder with the same name as the .ts file with the .properties extension added. It is a small text file that appears to contain some unique program ID When I then delete a show through SageTV, I find that the .properties file does not get deleted, so I end up with all these orphaned 1Kb text files in the folder.
Is this something that OpenDCT creates? Or is this caused by some setting in SageTV itself that I inadvertently set (like maybe does this have something to do with IMDB and metadata)? In any case, is there a way to turn that feature off so these files do not get created?
Chris
Old 02-16-2020, 02:42 PM
Tiki's Avatar
Tiki Tiki is offline
Those properties files are not from openDCT.
Sage can be set to create properties files for recordings. There are also some plugins that create properties files for recordings.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 02-17-2020, 07:31 AM
Thanks for the response.
I think I traced it to the "Upcoming Movies 2" plugin which installs the Complementary Metadata Tool (CMT) plugin.
Old 02-17-2020, 01:44 PM
MattHelm MattHelm is online now
This can be turned off. Not at home, but I can check tonight for the setting.
properties files darrylc SageTV HD Theater - Media Player 8 12-07-2010 10:09 AM
How do I get a .properties file from an ISO's in a video imports folder? mkanet Batch Metadata Tools 3 10-25-2010 05:32 AM
Properties files showing in Folder view mailman SageTV v7 Customizations 1 10-23-2010 02:09 PM
metadata properties file detail and folder estructure prado911 SageTV Customizations 1 10-06-2010 07:13 AM
Questions about my files and properties files jbuszkie SageMC Custom Interface 0 05-01-2009 03:53 PM
