Old 10-25-2010, 10:30 AM
Remote in Store for both Hd200 and HD300??
Are the remotes for these two units exactly the same or are they different? If different, which unit is the remote for that is for sale in the Sage Store???
Old 10-25-2010, 10:37 AM
QueOnda's Avatar
QueOnda QueOnda is offline
The remotes will work for all. The HD100 and HD200 are exactly the same remote. The HD300 adds learning function so you can actually power your tv and tv volume. Don't know what's in the store.
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone'
Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!!
HD200/HD300 Audio Questions.. jbuszkie SageTV Media Extender 4 10-01-2010 03:33 PM
Who is going to replace their HD200 with a HD300? pvrpenguin SageTV Media Extender 50 09-24-2010 12:02 PM
HD300 compared to HD200? ericscottf SageTV Media Extender 8 09-21-2010 09:45 PM
hd300 power adapter compatibility with hd200 impro SageTV Media Extender 4 09-10-2010 12:38 PM
store programs locally when under remote control from SageTV hufnagel SageTV Recorder Software 1 04-10-2004 08:43 PM
