Old 11-11-2011, 10:16 AM
Is this a possible HD300 replacement?
I just happened to come across this release about the popbox v8.
The design of the unit is almost the same as the HD300, which makes me wonder if the internals are the same as well. ie, I wonder if it would be possible to flash this using a firmware from an existing HD300?
I'm not willing to spend the money to find out... but maybe someone will
Old 11-11-2011, 10:31 AM
Fonceur's Avatar
Fonceur Fonceur is offline
They do say that the chip used is:
Chipset
Sigma Design 8671, 700Mhz CPU, 256 Mb DDR2 DRAM, 256 MB NAND Flash
Which might be a slightly newer version of the one in the HD300 (Sigma 865X). Since they allow plugins, and already have 80+, someone could probably develop a SageTV one.
It has been asked before for various boxes, and it's highly improbable...
SageTCPServer (2.3.5): Open source TCP interface to the SageTV API
MLSageTV (3.1.8)/Sage Media Server (1.13): SageTV plugin for MainLobby/CQC
TaSageTV (2.58)/TaSTVRemote (1.14): Monitor/control SageTV with an Android device
TbSageTV (1.02)/STVRemote (1.11): Monitor/control SageTV with a PlayBook 2
TiSageTV (1.64)/TiSTVRemote (1.09): Monitor/control SageTV with an iPhone/iPod/iPad
Old 11-11-2011, 10:39 AM
darcilicious's Avatar
Also keep in mind, not available in the US as of yet.
http://www.popbox.com/onlinestore/in...tedpg=reseller but a nice review of it here: http://www.mediasmartserver.net/2011...iew-popbox-v8/
Old 11-11-2011, 10:40 AM
aflat aflat is offline
Not even worth trying, I asked that already about similar hardware
http://forums.sagetv.com/forums/show...&postcount=903
Old 11-11-2011, 11:08 AM
PiX64's Avatar
PiX64 PiX64 is offline
I have faith in ya Sean. I think you can get it working :-)
Old 11-11-2011, 12:22 PM
emveepee emveepee is offline
It can run custom Flashlite/ ActionScript 2.0 apps and Syabas do partially expose their media player via an API so it provides more power than other customizable players like the Boxee Box. Apps for it will also run on the Syabas products A2x00, C200 and A300.
I have been trying to write a player for NextPVR using this but LiveTV support via the API seems to be limited and tech support for small developers is pathetic.
Martin
Old 11-20-2011, 08:45 AM
Torkild Torkild is offline
Martin
Thats so sad to hear.
NextPVR was/is my backup if Google dosnt come out with a enhanced "sagetv" product.
Live TV support and hardware ekstender with support of "what ever grab from the web of media files" + native output is a must have.
Keep trying - I migth end up with useing your good work if Google dosnt come true.
RMA HD-PVR, replacement from Amazon, do nothing? limiter Hardware Support 2 08-11-2009 02:00 PM
replacement osd bradlewa SageTV Customizations 3 09-19-2007 02:57 AM
Replacement MCE remotes? GTwannabe Hardware Support 1 09-10-2007 02:13 PM
Replacement for PVR-350 TV-Out SkierHiker Hardware Support 2 01-03-2006 04:58 AM
