SageTV Recorder Software Discussion related to the SageTV Recorder application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Recorder should be posted here. |
No Picture with Trial Sagerecorder in Australia
Hi All
Am trying to set up a PVR here in Australia (no Tivo or ReplayTV down here) Installed a Hauppauge PVR250 II about a week ago, which runs OK. Just downloaded the trial version of SageRecorder, which semed to install OK, but then just a bog black square on the screen. Tried different decoder settings, to no avail. Did get some audio after switching to 'Air' in Settings/Sources, then 'Autotune', but still no picture. Any suggestions? (Is the trial version not set up for PAL systems?) Note: Initially I had no sound with the PVR250 card, but fixed that by tweaking the driver set, according to some advice from the SHSPVR forum. It's now a hybrid 21062/20326 set (ie 21062 driver set but with the hcwpvrp2.sys from the 20326 set). Thanks Andy
Running Win XP on: Gigabyte GA-7VRXP mobo VIA KT333 AGP chipset AMD Athlon 1800+ CPU 512 MB RAM Seagate Barracuda ATA IV 60 GB HDD Nvidia GeForce2 MX/MX400+TV Out Graphics Card (by Sparkle) Creative Labs CT-4810 Soundcard Hauppauge PVR250 II TV Tuner |
I'm not sure what effect that custom driver set will have on SageRecorder. Have you tried Hauppauge's latest drivers with SageRecorder to see if that works?
Hi
Thanks for the suggestion. I resurrected the original WinTV200 driver set, & SageRecorder then had picture but no sound (as did WinTV2000). So I re-tweaked the driver set, and Lo! I had picture and sound with both SageRecorder and WinTV2000! Then I noticed I had nada through SageRecorder when I signed onto WinXP Pro as a non-Admin user; no picture, no sound, just grey screen. (Of course, now I can't remember how I was signed on when I had the original problems.) So, it seems I have a functional SageRecorder when an Admin user under Win XP Pro, but not as a lesser user. I installed SageRecorder when signed on as Admin; should this preclude using SageRecorder when signed on as non-Admin user? Andy
Did you install SageTV for all users, or just the one users when you went through the installation?
I'm pretty sure I installed for all users. I'm guessing there's no way to check this by looking at configuration settings somewhere, but that the behaviour indicates it's been installed for only 1 user, right?
Maybe I should just uninstall and re-install, taking care to install for all users this time. (Being a trial version shouldn't cause any problems with this, should it?) Andy
Dan Kardatzke, Co-Founder SageTV, LLC |
