SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
HELP - HD200 - No media Playback
Error:
"There was a playback error in Playback. Details: Sage.Playback.Exception" I get this when attempting to playback ANY media on the extender. I have tried power cycling the device. No Joy. I have tried deleting the properties files. No Joy As a note: It worked one day. Then Didn't work the next. Nothing changed in my Sage configuration. Everything except media playback seems to work. I do get playback on my client and Placeshifter |
Unplug it and if that doesn't work try deleting the .properties file for that extender in the Clients directory under SageTV.
Unplug both the power and network cables.
Plug in power and let it boot into standalone mode. Plug in network cable and let it obtain an ip address. Go to servers and choose your sagetv server. I have 2 extenders and only one of then does this. About once a month I have to reset it using this procedure. I hope it helps your situation. |
As I said in my first post,
I already Power Cycled (unplugged and plugged it back in) the device. And I also tried deleting the .properties file for the extender. It sees the server. I get the same error in stand alone mode when attempting to playback media!! I will see if forcing an IP change does anything. As it sits, my HD200 is a paperweight..... |
Have you tried rebooting the server? I get the same message occasionally and sometimes power cycling the unit solves it and other times I have to reboot the server.
How to Customize the STP-HD200 Media Player UI | Opus4 | SageTV HD Theater - Media Player | 5 | 11-28-2010 11:58 AM |
There was a Playback Error in Playback using HD200 | PRKIDD | SageTV HD Theater - Media Player | 4 | 03-16-2010 07:37 PM |
Question about getting media to the HD200 | SolidSnake745 | SageTV HD Theater - Media Player | 5 | 08-15-2009 01:17 PM |
Extender licenses with HD200 and Media MVP | Striker77s | SageTV Media Extender | 2 | 03-07-2009 03:25 PM |
