SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
HD200 - Unable to Connect to Sage
My HD200 is not connecting to Sage anymore... Sage is running. The Client will connect, Placeshifter will not.
On the HD200, it powers on, goes to the main menu (in standalone mode). It can see the Sage Server. When I attempt to connect to it, it powers off. I have tried power cycling the device (left it unplugged for a week). No Joy. I have looked at the \SageTV\Clients dir, there is only files associated to the Client, nothing for Placeshifter or Extender. I am tempted to believe that what is causing the extender issue is also causing the placeshifter issue... |
did you try the G+ suggestion of rebooting the box?
yes - much to my not wanting to reboot a server..
no change. I installed sage on a vm, and the extender connects to it fine... |
Well, I got it resolved!
I copied the SageTV dir from my server and the VM. Copied the VM SageTV dir ontop of my existing. Then copied the copy from my server on top of that. The only thing I can think of is a file went missing... Oh well, it works again!! |
Use HD200 from remote Location to connect to Home Sage Server? | eric3a | SageTV Media Extender | 5 | 01-16-2012 05:46 PM |
HD200 will not connect to server (Sage BSOD) | wikel | SageTV Beta Test Software | 7 | 09-21-2010 07:56 PM |
HD200 - Auto connect to Sage server when remote | madas | SageTV Media Extender | 5 | 02-28-2010 07:04 AM |
Mac Placeshifter is unable to connect | waffle | SageTV Placeshifter | 8 | 02-04-2007 08:16 PM |
Unable to Connect to the Sage Server with Sage Client | Snuffy2 | SageTV Beta Test Software | 5 | 03-08-2005 07:05 AM |
