Old 05-30-2012, 02:50 PM
antplugger antplugger is offline
Sage / DVBLogic PBDA driver development
Hi Guys,
Anyone interested and capable of developing (for a modest fee) a PBDA driver for SageTV so we could use the latest versions of DVBLink (http://www.dvblogic.com/).
This product is rock solid I have being using V3 for ages and really complementary to sage.
Cheers
Old 05-30-2012, 06:50 PM
jerryt jerryt is offline
+1
SERVER: Win 7 x64/i7-860/Zotac H55ITX-C-E/Corsair H70/CFI a7879 case/12 TB Pooled with Drive Bender. DVBLogic: streaming HDPVR content to SageTV, WMC Clients, NPVR Clients, Remote Computers & iphone. 2ea HDPVR, 3ea HDHomeRun, 2ea VIP211
Old 06-26-2012, 01:20 PM
Fredo44's Avatar
Fredo44 Fredo44 is offline
+1
AMD Phenom X6 1090T black,4GB Ram, ASUS Crosshair IV Formula,6TB onboard, 2x Digital Devices Cine S2 Dual DVB-S2 via unicable
Old 02-21-2014, 02:37 AM
DIBU's Avatar
DIBU DIBU is offline
+1
Sage V7x:
Server - Lenovo K320 with WindowsHomeServer2011, 10 Terabyte HD's on stablebit drivepool, (1 x DuoFlex CT Octopus PCIe DVB-C 4 Tuner all with LM-DVB-SmartRecorder, dbox2, run SageTV as Service, DeskNow Mail and Collaboration server, 2 Terabyte NAS (Ximeta) as seconf backup, 1Gb/s MSI ePower HD Network, 3xHD100, 1xHD200, 1xHD300, Panasonic LCD 55" TV, Sharp LCD TV, JVC LCD TV, Touchscreen LCD, PlaceShifter
cu at http://www.dbuschek.de
Old 02-22-2014, 02:22 PM
routerunner's Avatar
Originally Posted by DIBU View Post
+1
If your tuners are natively supported by SageTV and you need a simple solution to watch encrypted channels in Germany (HD+ package) THIS might help you instead.
Eddy
Old 03-04-2014, 09:32 AM
DIBU's Avatar
Eddy
thanks but i need PBDA driver for SageTV so we could use the latest versions of DVBLink
in the moment i use LM DVB Smartencoder but i would use DVBLink. I have my oscam server on my raspberry pi and it works great. Question..can i use with decryptor this extern oscam server?
Sage V7x:
Old 03-04-2014, 11:39 AM
With my solution the only thing you need is OSCAM running on the same machine as SageTV. OSCAM is very light on CPU consumption and unlikely other solutions I only send ECM/EMM to OSCAM when is necessary (typically every 10 seconds), so this is not an issue. The reason why I need to run OSCAm in the same machine is because my DirectShow filter makes the right OSCAM files when SageTV starts that OSCAM ingests .
The question is, does your tuner works natively with SageTV? If so you can use my solution in Germany directly, please send a PM to Wubdich which is one of my German users.
To answer to your question about OSCAM running on a different machine you still need to run one OSCAM on your Pi acting as a client to the other OSCAM server running on SageTV server, but for the reason I explained above, is overkill and totally unnecessary in my opinion.
Hope this helps
Eddy
Old 05-16-2014, 01:22 AM
DIBU's Avatar
Question ?
any news or is this also dead?
Sage V7x:
Old 05-16-2014, 09:22 AM
Have you considered my suggestion above?
Eddy
Old 05-16-2014, 11:55 AM
DIBU's Avatar
Eddy
Yes but my tv-cards (DuoFlex Octupus) DVB-C will not work directly with my sage.
so i hope for dvblink<->sage
Sage V7x:
Old 05-16-2014, 12:34 PM
I understand, but there is absolutely nothing we can do in order to make SageTV working with PBDA drivers unless SageTV is doing it, which unfortunately is not going to happen, so your best bet, in my opinion, is to replace the tuners with one that works natively witn SageTV and luckily few of my German friends are using the Digital Devices Cine series which are DVB-S2, C and T
Good Luck!
Eddy
Old 05-19-2014, 04:45 AM
DIBU's Avatar
well i have now DD cine DVB-C but Sage will not find any channel
i have in my freq-file DVB-C Germany with my Freqs... but no channel are found
Good Luck!
Eddy
Sage V7x:
Old 05-19-2014, 04:59 AM
There are two ways:
1) Update the PredefinedDVBC.frq and do a channel scan with SageTV.
2) Make the relevant "name of the tuner.frq" with all the channel listed, but you need to add every single channel manually in SageTV as well.
I'm sorry, but I don't have cable so I cannot help you any further. Please configure all the tuners/channels before installing the decrypter.
Eddy
Old 01-21-2015, 01:20 AM
DIBU's Avatar
Unhappy
Any News here?
Originally Posted by antplugger View Post
Hi Guys,
Cheers
Sage V7x:
PBDA Driver Support antplugger Hardware Support 6 10-10-2011 07:07 AM
Sage won't scan DVBlogic channels brewston SageTV United Kingdom 7 08-26-2011 01:49 PM
Microsoft delivers Protected Broadcast Driver Architecture (PBDA) Hector General Discussion 2 09-13-2008 11:04 PM
Sage Development Environment stuckless SageTV Studio 4 04-05-2008 06:14 AM
Sage Recordings Playlist Development..Any takers? Deadbolt SageTV Customizations 11 04-14-2006 05:43 PM
