Old 06-05-2016, 10:19 AM
turak's Avatar
turak turak is offline
DirecTV STB's
My Linux server stopped recognizing my HDPVR and I've been too busy with work to spend much time troubleshooting it. So I purchased a new HDPVR to replace it. It turns out the problem was just the power supply.
I now find myself with an extra HDPVR. I'm currently using a DirecTv Genie STB that I'm controlling with it's http interface.
I'm thinking about getting another STB and using this extra HDPVR. I'm not sure what the best option is for the STB though. Genie mini's don't have component or a web interface. I don't know if you can have two Genies on the same dish. I'd rather not use IR if I don't have to. Any suggestions?
Old 06-05-2016, 11:38 AM
bialio's Avatar
bialio bialio is offline
I'm in the same boat. From what I can tell the H24 receiver is the way to go - has component and web interface.
btl.
PHOENIX 3 is here!
Old 06-05-2016, 03:56 PM
btl.
H24 or earlier is the best but H25 should work. The component connects via a dongle if I remember correctly.
Old 06-07-2016, 07:44 PM
turak's Avatar
I added a H24. Works great. Thanks.
Old 06-20-2016, 08:16 AM
Savage1701 Savage1701 is offline
I thought the Genie Minis had that same "AV Output" plug on the back as the main Genie. Don't they? I am thinking of going to Directv so I would like to know that. Thanks.
Asus P5Q Premium MB, E6750, 4GB RAM, 32-bit XP Pro SP3, 3Ware 9590SE controller, 80GB 7.2K Laptop boot drive w/SuperSpeed Cache Utility & eBoostr, (1) KWorld ATSC-110, (1) 950Q USB, (1) 2250 tuner, (1) HD-PVR using USB-UIRT, (1) 1600 Dual card, (1) DVICO Fusion 5 Gold, (1) Hauppauge 1250, (1) Hauppauge 2250, 8 various storage HD's, NEC-based x1 USB add-on card, 2 outdoor antennas capturing 2 different OTA markets, Dish Network w/HD Receiver for HD-PVR.
Old 06-20-2016, 04:00 PM
The 4K minis do not have the AV Output on them.
Old 06-25-2016, 08:50 AM
KryptoNyte's Avatar
I have one similar to this device that seems to work very well and has 5.1 channel audio;
https://www.amazon.com/LOFTEK-HDfury...dp/B01CVM0JI2/
Directv H25 mfgolfnut Hardware Support 3 07-23-2015 08:05 PM
DirecTV D12-300 STB Help markdm Hardware Support 2 07-25-2008 11:27 AM
DirecTV on your PC Jesse General Discussion 41 02-15-2008 09:53 AM
help in Directv box RAKY0311 Hardware Support 4 02-19-2005 04:33 PM
Directv justlearnin SageTV Recorder Software 1 03-25-2003 05:12 PM
