OpenDCT: Can I use it?
I see the thread on OpenDCT and I'm wondering if I can use it with my configuration. I see the thread and the discussion about using it with HDHomeRun but I've got an HVR-2250 and HD-PVR (Cablevision SA4250HD). Would I benefit at all if I was able to use this? I'm currently having frequent lock-up issues so I'm looking for any other options.
SageTV User Since 2009 Server Hardware: AMD FX6100, 6 Cores, 3.3GHz, 8GB RAM, TA970XE MB, 3TB HD, HVR-2250, HD-PVR, nVidia 9600GT 512MB Server Software: SageTV 9, Windows 10 64bit, EventGhost Client Hardware: HD200 x2, INT-422-3 & WR7 Remote Service Provider: Cablevision (QAM to 2250, SamsungBox to HDPVR) |
As to the frequent lock up, is that on the server or is that on the client/extenders? If it is on the client or extenders, then it is probably a network issue. If it is on the server, then it is probably a hard drive issue.
Media Server: Win 7 Home (32 bit), GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard, Intel Core 2 Quad Q9505 Yorkfield 2.83GHz, 4 GB Ram, Geforce 9600 GT PCI-E, 1x HD PVR, HD homerun (2x for OTA, 1x for FIOS QAM), 1 x HD Homerun Prime with cablecard from FIOS. Client: Windows 10 Pro Media Extenders: HD-200 x 3, HD-200 x 2 |
Thanks for the quick reply. I thought OpenDCT had a specific use but wasn't completely sure.
As far as the lockups go... they mainly happen when I'm watching a program that is also a scheduled recording. If I try to fast forward it will frequently lock up with the spinning wheel. It happens on the server and clients.
Channels DVR UBUNTU Server 2 Primes 3 Connects TVE SageTV Docker with input from Channels DVR XMLTV and M3U VIA Opendct. |
Curious, as support for these are built into SageTV, what are the advantages for using this solution over the built in support?
Right now I share all my tuners with the HDHomerun DVR ... WMC ...NEXTPVR .. and my test system. PS.. Remember SageTV does support these tuners but does not check to see if they are in use prior to trying to tune it.... If it is in use you will get an error in the recording... SageTV only knows what tuner it is using will not check if other APPS are viewing TV on that tuner.
Channels DVR UBUNTU Server 2 Primes 3 Connects TVE SageTV Docker with input from Channels DVR XMLTV and M3U VIA Opendct. Last edited by nyplayer; 02-20-2016 at 06:36 AM. |
k |
What part of your system is locking up? Is it the HD-PVR? If so, what version of HD-PVR driver are you using?
I went thru months of grief with frequent (almost daily) problems with the HD-PVR when using the "latest" driver v1.7.1.30059 (released on 2012-03-25). Reverting to the older v1.5.7.0 driver (dated 2010-06-24) has been rock-solid; it's been up for over a month now.
System #1: Win7-64, I7-920, 8 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HDHR-US (1st gen white) tuners. HD-200. System #2: Win7-64, I7-920, 8 GB mem, 4TB HD. Java 1.8.0_131. Sage v9.1.6.747. ClearQAM: 2x HDHR3-US tuners. HD-200. System #3: Win7-64, I7-920, 12 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HVR2250; Spectrum Cable via HDPVR & USB-UIRT. 3x HD-200. |
OpenDCT: An open source digital cable tuner. | EnterNoEscape | Hardware Support | 2947 | 05-29-2022 08:40 AM |
OpenDCT Java Network Encoder | spencerw | Hardware Support | 62 | 05-19-2016 08:18 PM |
InfiniTV4 with OpenDCT | tomdomm | Hardware Support | 58 | 02-03-2016 07:00 PM |
