Old 04-21-2003, 06:09 PM
Mark Lamutt's Avatar
Mark Lamutt Mark Lamutt is offline
Hauppauge PVR-350 composite input
I tried connecting my dish network receiver video via composite video cable and the svideo-to-composite dongle that came with the 350. I didn't get what I expected out of Sage - the picture was completely black and white. No color, no matter what channel it was tuned to.
Driver problem? Dongle problem? Other suggestions? When I connect via svideo cable, all is good.
I'm running the latest drivers posted on SHS's site, after going through the cleaning procedure he lists there.
Mark
mark@freytechnologies.com
The picture is of my kitty, Myko at 9 months old.
Old 04-21-2003, 06:38 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
To fix the b/w problem, do the following:
1 - Quit SageRecorder/SageTV
2 - Open the SageRecorder.properties or Sage.properties (for SageTV) file with Notepad
3 - Find the lines that have (... will be a large number):
mmc/encoder/..../3/0/video_crossbar_index=0
mmc/encoder/..../2/0/video_crossbar_index=0
and change them to be
mmc/encoder/..../3/0/video_crossbar_index=1
mmc/encoder/..../2/0/video_crossbar_index=1
NOTE: if you have multiple tuner cards, you'll need to find the encoder section that refers to the Hauppauge card. The /3/ property fixes S-Video, the /2/ property fixes composite.
4 - Save the file and quit Notepad
5 - Start SageRecorder/SageTV and you should have color on the s-video/composite instead of b/w.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 04-21-2003, 10:41 PM
When I changed the svideo (the /3/ setting) from 0 to 1, I lost the entire picture when connected via svideo cable. Setting it back to 0 restored the picture. When I changed the composite setting from 0 to 1, went through the setup wizard again to modify the source from svideo to composite_2 (that's what was listed), exited SageTv, and then restarted, I had color from the composite input.
Mark
