Old 12-11-2016, 02:58 PM
tvmaster2's Avatar
rebuilt Sage partially, missing plugins...
A few plugins don't seem to be around, or at least gave me errors when I tried to reinstall them after doing the mini rebuild.
They show up in the plugins directory via Sage, but give me errors:
Enable/Disable Favorites 1.3.1 by skiingwiz
GKusnicks Tools Library 1.5.5
SageTCPServer 2.3.6 by Fonceur
STVI Configurator 1.0.8 by GKusnick
Anyone know if these should work, or are discontinued and links broken?
thanks
Old 12-11-2016, 07:55 PM
Fonceur's Avatar
Fonceur Fonceur is offline
You can get SageTCPServer from:
https://dl.dropboxusercontent.com/u/...rver-2.3.5.zip
I think with a proper SageTVPluginsDev.xml in your SageTV folder, you could install it, something like (MD5 is wrong, as it was for an older version):
https://dl.dropboxusercontent.com/u/...PluginsDev.xml
If you still have access to your previous build, you can probably get the other files from it...
SageTCPServer (2.3.5): Open source TCP interface to the SageTV API
MLSageTV (3.1.8)/Sage Media Server (1.13): SageTV plugin for MainLobby/CQC
TaSageTV (2.58)/TaSTVRemote (1.14): Monitor/control SageTV with an Android device
TbSageTV (1.02)/STVRemote (1.11): Monitor/control SageTV with a PlayBook 2
TiSageTV (1.64)/TiSTVRemote (1.09): Monitor/control SageTV with an iPhone/iPod/iPad
Old 12-14-2016, 01:20 PM
tvmaster2's Avatar
did your app relay on this:
<Plugin>GKusnickToolsLib</Plugin>
If so, that's also missing from the Plugins downloads - it shows up as a plugin, but when I try to download it, I get an error. Any thoughts?
Which plugins should we include as core plugins, if we were to auto-install plugins? stuckless SageTV Github Development 35 07-08-2016 04:01 PM
Metadata Tools missing from Installed Plugins barney B.A. SageTV v7 Customizations 1 06-28-2010 12:14 PM
Sage not deleting partially watched live TV? K O SageTV Software 19 02-06-2010 06:00 PM
rebuilt box, cant get DD passthrough idvsego SageTV Software 1 06-12-2008 02:22 PM
Rebuilt System, No Joy, NVIDIA Humanzee Hardware Support 4 11-11-2005 04:53 PM
