Old 09-21-2017, 04:23 PM
al_uk al_uk is offline
Import/Export lineup - file created in wrong directory with wrong name (Docker)
I'm making the switch from v7 on Windows to V9 as a docker on UnRaid.
I am in the UK using HD HomeRuns.
I have my new frq file and now need to do the mapping between it and SchedulesDirect using the import/export plugin.
When I press "Export Enabled Channels on Lineup" the file is created in the root of the mapped directory into the container. This is /opt/sagetv rather than /opt/sagetv/server. The export file name is called "SQVHXZ~P" without the quotes.
If I then select "Import Channel Lineup" The sample import file is again created in /opt/sagetv not /opt/sagetv/server and is called "SL4MF6~O" without the quotes.
I am not peeking inside the container, I am just looking at the mapped directory outside the container.
The files should be called "HDHomeRun 1230a1f8 Tuner 0-0-DVB-T.export"
Any idea what is going on here? The import FAILS even if I modify the SL4MF6~O file.
Thanks.
Old 09-23-2017, 06:07 AM
Is the "import/export plugin" something that sagetv provides? Or is this an actual plugin? I've never heard of it, but, I also don't use .frq files either
This seems like an issue with plugin, itself. Have you ever tried it on Linux?
Old 09-24-2017, 01:33 PM
It is a separate plugin. I've not tried it directly on Linux, but it worked well on Windows v7.
I used it to rearrange the order of channels and disable the ones I wasn't interested in.
The problem I am trying to solve with v9 is this.
Here are the 1st few frq enties from a channel scan.
CH:1 onid:9018 tsid:4163 sid:4163 frq:498000000 band:8 ctrl:1 #:BBC-ONE-South
CH:2 onid:9018 tsid:4163 sid:4287 frq:498000000 band:8 ctrl:1 #:BBC-TWO
CH:3 onid:9018 tsid:4163 sid:4544 frq:498000000 band:8 ctrl:1 #:BBC-FOUR
CH:4 onid:9018 tsid:4163 sid:4608 frq:498000000 band:8 ctrl:1 #:CBBC
CH:5 onid:9018 tsid:4163 sid:4672 frq:498000000 band:8 ctrl:1 #:CBeebies
Note the 3rd entry is "BBC-Four"
The Schedules Direct EPG has "ITV" as the 3rd entry. When I select that channel from the guide or when previewing a tuner, then it actually tunes BBC-Four.
I do have an excel file which can break out the FRQ, I'm just not sure now what I should do. Should I change the FRQ file so that the 3rd entry "CH:3" has the SID for ITV?
Cheers.
Old 09-25-2017, 05:58 AM
Cheers.
If I had to guess, since this was working on windows, is that the plugin likely is not handling the filesystem correctly. A common issue for devs that primarily develop on windows is to use windows paths in java, and those don't work in linux. (ie, something like \somedir is not a valid pathname in linux, it would need to be /somedir... fortunately, if you use the latter format it works in both windows and linux)
Old 09-25-2017, 07:43 PM
Stuckless, thanks for that pointer. That was enough for me to edit the ImportExportChannelLineup.stvi and change the 2 lines that build up the paths for the import and export files.
It now works.
Cheers.
Old 09-26-2017, 06:21 AM
It now works.
Cheers.
That's good news. Is this stvi still being maintained? If so, it would likely be good to get a permanent update for others as well.
Old 10-24-2017, 03:55 PM
rickgillyon's Avatar
Does anyone know if this plugin was fixed? Or is there a working version somewhere that I can have? Just to save me a couple of hours remapping...
Old 12-18-2017, 07:44 AM
Same question as above? I have grown rather fond of export/import as my schedules direct download for Dish network always needs a ton of attention if I have to go from scratch. Just moved to Docker and hoping for some timesavers.
Old 12-18-2017, 08:14 AM
I never found a way to make it work. It does export the lineups, with a nonsense filename and no extension, in /appdata/sagetv so you can use those as reference, put them in Excel and sort them etc. But no way to import, it never finds the import files.
Old 12-18-2017, 08:45 AM
Should have had a look instead of just whingeing about it.
5 lines have:
Just change to:
It exports okay, don't want to risk an import right now.
Attached is the updated stvi. Copy to /sagetv/server/STVs/SageTV7
Old 12-19-2017, 01:45 PM
texneus texneus is offline
Used it last weekend and it worked fine for me to. The export created the file in the opt/sagetv directory as noted above, but prefixed by a windows path (i.e. the file name was server\blah blah blah blah.export). i just moved it to the right spot, dropped the path from the filename, and renamed it to .import.
I.e. mv "server\blah blah blah.export" server/"blah blah blah.import"
Lineups imported without issue. This is an old plugin, I remember using it a number of years ago. It's probably no longer maintained.
Server: Asrock C236WSI, Xeon E3-1225, 32GB RAM, NAS4Free (FreeBSD) 11.1 w/Ubuntu VM for SageTV
Tuners: HD Homerun Quatro (OTA), Hauppauge Colossus HDMI capture (CATV)
Clients: SageTV client on Windows 7 HTPC, NVidia Sheild
Old 12-19-2017, 04:09 PM
I am pretty sure that is the case but when I PMed the author he got back to me pretty quickly. I think it was studebaker69?
Import/Export Channel Lineup lenkost SageTV v7 Customizations 12 06-04-2017 04:57 PM
Import/Export Channel Lineup not working RickE SageTV v7 Customizations 7 05-12-2011 03:11 PM
Some wrong files in video import directory rerooks SageTV Software 4 04-27-2009 12:16 PM
Wrong lineup on one channel (CMT)... jriskin SageTV EPG Service 1 11-09-2008 06:00 PM
Sage Recording In The Import Directory - Wrong Place mike1961 SageTV Software 2 08-20-2006 08:34 PM
