Old 03-24-2008, 02:57 PM
Mtlca401 Mtlca401 is offline
When recording, in grouped playback, is over sageTV jumps back to recording menu...??
When I play a group of recordings sage jumps back to the recordings menu between the times of one show ending and another beginning. Or if this makes more sense, once a show is over it goes back to the recordings menu even though it has another show to play within the group. It has not done this before and the only thing that is different with my setup is that I have satellite now.
Also once the group is finished playing it goes to the playlist tab in the videos menu instead of back to the recordings menu. It has always done this.
Old 03-24-2008, 03:51 PM
What STV are you using, and what version is it? This is listed on the System Information screen -- use Info while on the Main Menu.
Are you using SageMC or did you recently try it out? If so, make sure this property is set to false, because that STV sets it to true:
videoframe/always_call_fileplaybackfinished=false
Old 03-24-2008, 04:12 PM
Actually I did try out the SageMC yesterday and then switched back. I changed this setting back to false. I'll see if that works.
thanks
STV Import: Video Editing for Sage BobPhoenix SageTV Customizations 279 03-07-2013 01:35 PM
livetv recording jumps to realtime DRAK SageTV Beta Test Software 22 07-11-2007 05:26 AM
STV: MlbDude2 1.8.7 - July 5 mlbdude SageTV Customizations 583 11-08-2004 04:18 PM
