Old 07-19-2006, 07:07 PM
webfire webfire is offline
updating mvp.bin - how?
I've read where people are trying a new mvp.bin for their Media Extenders. I've downloaded the file. Does it just deploy onto the Sage server, perhaps on top of an existing mvp.bin?
Old 07-19-2006, 07:12 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Yeah, just overwrite the one in your Program Files\SageTV\SageTV folder. (and, you should probably back it up first)
Jeffrey Kardatzke
Google
Founder of SageTV
Old 07-19-2006, 09:39 PM
Fallen Kell Fallen Kell is offline
yeah just rename the original mvp.bin to mvp.bin.orig or something, and then copy the new one into that same directory (the "Frey Technologies/SageTV" directory).
HTPC: Intel i5-4670, 8GB DDR3, PowerColor HD5750 SCS3, Intel 510 120GB SSD, 8TB storage disk space, LG GGW-H20L BD-ROM, 3x Sony VGP-XL1B3 200 disc Media Changers, Win7 Premium 64bit, Haupauge HD-DVR 2 Gaming Edition Plus
Old 07-22-2006, 11:32 AM
Should the Rev change on the MVP splash screen? Mine is still reading 2.05. Is there something to check to see if the update took place?
I'm not sure I'll be able to check. I now appear to be stuck at the Loading Application screen.
Old 07-22-2006, 05:25 PM
carlgar carlgar is offline
I encountered the stuck issue last night and discovered that when I disconnect power, I have to wait a minute or two before reconnection to force the application to reload. I was just waiting a few seconds before, but that was for my wired MVP, the wireless seems to require a longer wait.
I am not sure when it was added but I noticed with the new version of the mvp.bin, use of the remote will cause the power led to flash for a second or two. I think this could be a new feature to let you know a remote signal was received by the MVP.
