Old 01-11-2007, 01:39 AM
matrix35 matrix35 is offline
Do away with HIP for good! with MCE remotes
well I've been trying to get rid of HIP for a while. suffice to say I've been highly inspired by plugins available for MediaPortal, I've come up with this two part solution:
1. a program to monitor MCE remote's Greenbutton.
2. a program to use MCE blasters with stock winxp drivers.
before you go on I'd like to mention that these are based on MP plugins that their owners have worked hard on them, I've only adapted them for sagetv and added a couple of features. Full credit should go to Smirnuff (MPTray) and Michel (MyBlaster).
Instructions:
0. You need .NET Framework2.0 installed.
1. Keep MCE receiver's stock drivers installed.
2. Download "Sagetray.zip" and follow the readme.txt, this will let you use the Green button to launch and/or get back to SageTV
3. Download "Blaster.zip":
... 3.1.unzip the attached file.
... 3.2.launch "Blaster.exe" it is the learn program. program in your remote's keys
... 3.3a.Install ExeTuner as mentionned here: http://forums.sagetv.com/forums/show...0&postcount=10
... 3.3b.follow the example used in the batch file to configure ExeTuner with MCEBlaster.exe the syntax is similar to HIPSend
well that's about it. I was really frustrated with HIP and of the number of programs that had to be configured in order for it to work.
hope this helps someone.
Changes
Added '/app' parameter to specify exe to launch with green button.
EDIT:
Sorry folks it just came to my attention by bmellesmoen that I shouldn't be releasing this program since I don't adhere to GPL (although I did get written consent from their author).
I don't need the headache. if someone still needs them let me know.
Old 01-11-2007, 07:30 AM
Just to avoid any potential of the kind of disaster that happened with some MP themes in the past - you asked them for permission, right ?
Dirk
Old 01-11-2007, 07:56 AM
heffe2001's Avatar
Looks to me like it's not a theme, he's using the existing mptray & blaster software and configuration for using it in Sage, so there shouldn't be a problem (but would say asking would be a good idea anyway, never know with some people what their reaction would be).
Old 01-11-2007, 08:20 AM
to be honest i didn't, I just got the source code that comes with the plugins. but you're right better be safe than sorry. I'll retract the files for now until I get their ok.
Old 01-11-2007, 10:37 AM
Forged1 Forged1 is offline
Man, I'm looking forward to this! The green button works great once I'm in Sage, but I've always wanted it to fire up Sage when I'm back at a Windows desktop.
I hope the original author doesn't mind you sharing your mods.
Old 01-11-2007, 11:25 AM
brewston brewston is offline
I thought certain buttons (the green one, the guide) didn't work within Sage ? Its whats been putting me off getting that remote
Tim
Tecra M5, 2 x HD200, 2 x HD300
2 x PCTV 290e
Win 7, Sage 7.1.9, Phoenix 2 STV
Stephane's XMLTV Importer, Digiguide,
Old 01-11-2007, 11:39 AM
Hi,
In Sage, the green button brings me back to the main Sage screen. I'm running Sage in Windows MCE. I just made sure that none of the MCE services or startup programs are running.
So far so good. But, with the apps mentioned above, it could be better
I'm not new. I just like to read a lot.
Old 01-11-2007, 12:46 PM
well I've got the ok from Smirnuff waiting for Michel (unless he's one and the same).
http://forum.team-mediaportal.com/sh...ad.php?t=14785
Old 01-11-2007, 02:52 PM
blade blade is offline
Tim
Every button on the remote works with Sage's built in support.
Old 01-11-2007, 11:58 PM
the files are now back.
Old 01-12-2007, 05:26 AM
Dirk
Old 01-12-2007, 07:12 AM
Awesome! I'll try this out tonight.
Old 01-12-2007, 02:14 PM
bmellesmoen bmellesmoen is offline
matrix35,
Would it be possible to post the source for Sagetray, MCEBlaster, and Blaster as well?
Thanks, Bob
Old 01-12-2007, 11:08 PM
Hi,
I just wanted to let you know the sagetray app is working great. Hitting the green button on my remote now fires up Sage if it's not running
Old 01-12-2007, 11:14 PM
Hi,
glad to hear its working for you
Old 01-13-2007, 12:07 AM
Sagetray doesn't appear to work with Sage TV client. And I'm guesiing it's because the .exe is different from SageTV server. (SageTVClient.exe)
Old 01-13-2007, 01:58 AM
a new version is posted. Edit the sagetray_install.bat file to specify sagetvclient.exe instead of sagetv.exe
this should now work.
Old 01-13-2007, 01:03 PM
Sorry if this is a stupid question. Do I need to run the batch file every time windows starts or does register put it in the run cmd? Talking about sagetray
tia
b
EDIT: Thanks for making these available!
Old 01-13-2007, 01:12 PM
tia
b
Once you run the install and sagetray is registered it loads everytime.
Old 01-13-2007, 01:13 PM
Works great for the client. Thanks for the change.
