Old 09-09-2009, 01:46 AM
VCRUser VCRUser is offline
Preview/Live TV fails on some channels
I think this started when I updated to the latest STV (6.6.2.9 September 4 2009, stv file set 2009090401; Sage 6.6.1.217). When I try to preview or live-view certain OTA channels on my ATSC tuners (3.1 and 10.1 seem to suffer from this, but not 10.2 or some higher channels), I get a black screen. Recordings made on those channels are ok, though. Also, when I've tried to tune some channels that aren't tunable, I've twice gotten BSOD. I suspect the STV is to blame, since I didn't have this problem before the stv update, so how do I revert to a previous one? It appears that at least some, but not all previous versions are automatically backed up when updating, but it would be nice to be able to get the most recent set to figure out which is the best one to use. Anyone else experiencing this?
Server: Windows 7 SP1; 4gb RAM; 2TB SATA. Dell GX745. Inputs: Haup. 850 & 950Q on ATSC; Haup 1600 on ATSC & Comcast DTA with USBUIRT. Haup 1800 on ATSC. Sage 9.
Old 09-09-2009, 09:34 AM
I don't see how any of the recent STV updates would affect this, but the previous version is still in the STV directory with the version number added as an extension at the end of the filename. It sounds more likely to me that you have tuner or signal problems.
Old 09-10-2009, 12:07 AM
It shows up only for certain channels on the same tuner (the recordings come out fine and play fine on the Extender, but black-screen on the server gui) & is new since I updated STV. When I did the STV update, there were several updates in a row, so I'm not sure which older versions were saved (i.e. how far back). In any event, what is the procedure for restoring older STVs to see if that fixes the problem: do I just rename them, rename and move to another directory?
Old 09-10-2009, 12:46 AM
Have you updated anything else recently? Did you add any tuners or TVs & needed to split the cable to do so? Change any decoders on the server PC?
The older STVs are simply renamed to SageTV3.xml.<version number> All you need to do is copy the file to something like SageTV3_<version number>.xml and load that as your STV for testing.
Old 09-10-2009, 02:45 PM
I configured my usbuirt to work with my Comcast DTA, and yes, this did involve some splitting, but only on the cable side, and the problem appears on the ATSC side. I also fairly recently switched video from overlay to "default" to cure the pink screen of death that had recently cropped up on occasion, and was wondering if that was relevant; I may try switching back and/or to a different display option. The other video-relevant problem I've had ever since I upgraded to a larger, widescreen, monitor is that if I leave the gui up for any length of time, it acquires black bands around it, obscuring part of the window. I have to shut down & restart the gui to cure that. That occurred before updating STVs, though, so I'm not looking to them as a cause for that particular issue. The pink SOD I had was only on the server gui, the black screen was on the server & placeshifter but not on the extender. The blue SOD occurred when trying to tune untunable channels, when attempted from either placeshifter or server.
Thanks to your reply on how to revert to earlier STVs, I'll fiddle with them this weekend to see if that makes a difference to at least some of these issues.
Should the video preview window be showing for parental locked channels ? AtariJeff SageTV Software 0 06-11-2008 10:11 AM
When TV is live, sagetvtranscoder.exe fails to start jmann SageTV Placeshifter 4 10-04-2007 12:38 PM
Live Preview question trace594 SageTV Software 0 09-04-2007 07:15 PM
All channels showing "No Signal" - but tuning preview works! sjgore Hardware Support 4 01-26-2007 02:47 AM
Missing Channels in Live TV Guide MSquid SageTV EPG Service 0 08-11-2004 12:40 PM
