Old 04-20-2011, 09:53 AM
pieroxy pieroxy is offline
Question Difference btw Media Server and Media Center
I have noticed that on the free downloads one can download Media Center (Windows or Mac) or Media Server (Linux)
What is the difference between both products?
Old 04-20-2011, 10:01 AM
Fonceur's Avatar
Fonceur Fonceur is offline
I think the Linux version has no built in UI, so requires a client to connect to it...
SageTCPServer (2.3.5): Open source TCP interface to the SageTV API
MLSageTV (3.1.8)/Sage Media Server (1.13): SageTV plugin for MainLobby/CQC
TaSageTV (2.58)/TaSTVRemote (1.14): Monitor/control SageTV with an Android device
TbSageTV (1.02)/STVRemote (1.11): Monitor/control SageTV with a PlayBook 2
TiSageTV (1.64)/TiSTVRemote (1.09): Monitor/control SageTV with an iPhone/iPod/iPad
Old 04-20-2011, 10:07 AM
panteragstk's Avatar
Media center is both server and ui if you want to use the server to view media.
Old 04-20-2011, 10:09 AM
Ok, all extenders, placeshifters and clients would work all the same?
Old 04-20-2011, 10:15 AM
Ok, I think I get it. I have a few questions on the Server:
1. How do you configure your server is you don't have a UI?
2. How can I evaluate the free version without a UI? Do I need to also download a client for Windows or Mac?
Old 04-20-2011, 10:47 AM
Fonceur's Avatar
You could use the Linux client/placeshifter on the same pc...
Old 04-20-2011, 12:38 PM
PlaceShifter is a client that will let me configure the server? What's the difference btw PlaceShifter and a Client then?
There is no client for Linux (at least in the free download section)
Old 04-20-2011, 01:17 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Basically, thin client v. thick client, optimized for different use cases. Placeshifter is designed primarily for portability and remote use over the Internet. SageTV Client is meant for high-bandwidth LAN use, with greater flexibility in playback options. See the FAQ for more details.
-- Greg
Should I buy SageTV Media Center or Media Server? (re: headless server box) sofakng SageTV Software 5 03-12-2011 03:56 PM
Figuring out my first media center home server combo vosovich Hardware Support 4 12-03-2009 03:41 PM
Media SERVER vs. Media CENTER Farm SageTV Customizations 7 05-26-2009 08:36 PM
Raid for the Media Center Server OS or not? Stuntman Hardware Support 0 12-05-2008 04:58 PM
Media Center or Server? wayne186 SageTV Software 5 09-04-2008 10:16 PM
