Old 12-01-2004, 11:01 AM
invisible_ink invisible_ink is offline
Not updating?
Hey kids,
All of a sudden SAGE isn't updating my scheduling information. Which is to say, if I search by title I can seem to find the titles of shows, but when I select any show available then I get "zero instances of this show found". Then I discovered that the "Live TV Guide" is a mass of no data. How do I force SAGE to update?
ink
Old 12-01-2004, 11:29 AM
CyRex CyRex is offline
You can force Sage to update the EPG data by going into channel setup and removing and then re-adding one of your channels.
Also, try looking at the System Information under the Setup menu and check when your last EPG update was.
Are you using the default method for EPG (ie Zap2It)?
Old 12-01-2004, 11:30 AM
pcuoco's Avatar
pcuoco pcuoco is offline
Here are instructions for forcing an update from the FAQ.
http://forums.sage.tv/forums/showthr...3827#post43827
You may want to double check that your internet connection is working as well.
