Anyone with wireless MVP success stories?
I purchased a wireless MVP from Sage without noticing all the negative threads posted here about it.
And wouldn't you know it, the wireless connection is crap. It hard locks my Linksys WRT54G wireless router. I am really happy with its wired performance, though. So, does anyone have one of these working well wirelessly? If so, care to share any tips on getting it to work properly? Any recommendations for compatible hardware? Last edited by jkf; 06-08-2007 at 08:48 PM. |
I have a feeling all we are going to hear/read in this thread are crickets chirping.
![]() -PGPfan
Sage Server: Gigabyte 690AMD m-ATX, Athlon II X4 620 Propus, 3.0 GB ram, (1) VistaView dual analog PCI-e tuner, (2) Avermedia Purity 3D MCE 250's, (1) HD-Homerun, 1.5 TB of hard drives in a Windows Home Server drive pool, Western Digital 300GB 'scratch' disk outside the pool, Gigabit LAN Sage Clients: MSI DIVA m-ATX, 5.1 channel 100w/channel amplifier card, 2 GB ram, , (1) Hauppauge MVP, (1) SageTV HD-100 Media Storage: unRAID 3.6TB server |
I have the exact same setup you do and mine is running just fine, no problems.
The only difference is I'm not running the "stock" firmware in my router. I'm running http://www.dd-wrt.com/dd-wrtv2/ddwrt.php . |
If the wireless MVP has an ethernet port, I suppose you could buy/use an 802.11g wireless bridge, though it wastes the MVP's wireless, such as it is.
I too use DD-WRT. December '05 version. Absolutely rock solid. Maybe the only shareware I've ever had that is. Runs the Sage PC client wirelessly and flawlessly. Strong signal though; -70 to -80dBm. |
Before doing this, my wMVP was unable to get an address. now, it works like a champ and the wife is happy that I did't need to cut the house up to run a ethernet cable. ![]()
Server: AMD 2500+, 512mb Ram, 840GB Total HDD Space, 3x WinTV-PVR-250 to Suddenlink Basic Cable, 1x TV Wonder 650 to OTA ATSC HD Signal. All in the laundry room, with case open, cooled by a box fan. Client1: HTPC Case, GF8500 Fanless Video Card, P4 3.2Ghz, 1GB Ram, MSI 945GM3-F Main Board, 500w Silent Modular Cable Power Supply. Connected to 37" LCD HDTV by VGA cable. 2.1 Speakers for sound. Running SageTV 6.1.9 with SageMC + Google Calender (WAF 9.5/10) Client2 & 3: MediaMVP's with SageMC |
Stupid me, I got the WRTP54G router. The only difference is the built-in Vonage support. I have heard of a multitude of problems with this router and that the hacked firmware versions out there seem to fix all.
But I can't seem to find one that is designed for my WRT(P)54G router. Anybody know of one or if I can use the one for the WRT54G?
If this doesn't work right, Then: "I'm going to blow up the Earth!" |
I've been using a wireless MVP with a WRT54G router for 7 months now with no issues at all, it has received a very high WAF. Prior to this I had it connecting to a Netgear WGR614 which game me nothing but headache, unable to connect, disconnections, lockups, etc.
SageTV 7, Windows XP Pro SP2, Pentium E5300, 2GB RAM, Pinnacle PCTV 80e, Kworld PlusTV HD PCI HDTV Tuner, HD300, HD100 Last edited by KeithTX; 06-12-2007 at 03:14 PM. |
Some current production Buffalo models are DD-WRT compatible. see http://www.dd-wrt.com/phpBB2/index.p...14048e228afb14 |
Sorry, nothing but problems here. I have been back and forth with support many times and have given up. If you want wireless, you need a bridge is my conclusion.
Wireless MVP Information Request | emveepee | SageTV Media Extender | 0 | 11-28-2006 11:56 PM |
ADSL Routers and Wireless MVP | doc | SageTV Media Extender | 0 | 10-28-2006 08:23 PM |
Wireless Access Points that work with MVP | Chad | Hardware Support | 4 | 09-25-2006 12:15 AM |
Poor Wireless MVP connection | DaFrogBoy | SageTV Media Extender | 0 | 08-30-2006 10:53 PM |
New Wireless MVP won't connect to SageTV server. | exclavieor | SageTV Media Extender | 0 | 07-19-2006 05:11 PM |
