Old 10-01-2007, 01:27 PM
TechBill's Avatar
TechBill TechBill is offline
Can SageTV Linux use same plugins as SageTV XP Windows?
Right now I got SageTV running on XP Windows but wonder if SageTV linux could use the same plugins as the Windows version?
Plugins like SageMC or Closed Captioned addon etc or direct to DVD burner etc.
Bill
Old 10-01-2007, 01:34 PM
Yes & No... each type of client can use the same STVs & so on, but whether a particular customization uses anything specific to one OS depends on the customization. You mentioned a few customizations, but if there are others, then you should mention each one you are asking about, or check in the customization's topic.
Old 10-01-2007, 02:33 PM
TechBill's Avatar
Ok thank you!
Bill
Old 10-02-2007, 12:59 AM
nielm's Avatar
nielm nielm is offline
Rule of thumb:
If a customisation is an STVI only, it will probably(*) work fine on linux
If a customisation is an STVI + JAR, it will also probably(*) work fine on linux
If a customisation uses external DLLs or EXEs, then it won't run on linux unless the developer has linux equivalents.
(*) unless it has to run Windows programs, or call to windows DLLs then not. This is fairly rare...
All of my plugins should run on linux, except for the cpu/mb monitor which uses windows DLLs and system calls.
EvilPenguin's dvd burner uses windows exe's built from perl scripts, so may be able to run on Linux after some modifications. However, Linux should have native dvd burning support.
Windows Verses Linux davephan General Discussion 6 06-06-2007 07:35 AM
Purchasing Windows and Linux versions? morikaweb General Discussion 19 05-22-2007 09:05 PM
Linux VS Windows questions? dpackham SageTV Beta Test Software 8 12-15-2006 07:20 AM
Linux version install errors rschellenberg SageTV Linux 4 08-06-2006 09:16 PM
Windows -> Linux migration question pciccone SageTV Linux 8 01-16-2006 01:00 PM
