SageTV Linux Discussion related to the SageTV Media Center for Linux. Questions, issues, problems, suggestions, etc. relating to the SageTV Linux should be posted here. |
SageTV Server running Linux? Any success stories?
A month or so ago I was preparing to purchase and build a new Quad-Core SageTV server and decided to put that project on hold until I had the HD-PVR things all worked out. I'm still not quite ready yet, but was wondering if it would make any sense to set the new server up in Linux. Here's a few questions for folks running something like this?
Are there any working (working well) SageTV servers running linux? Does the HD-PVR work with SageTV's linux version? What are the dissadvantages of going with Linux for the SageTV server? Any and all input is welcomed as I'm mostly just in the fact-finding stage of this. Thanks, |
There are quite a few success stories I think around the block.
It is NOT for the faint of heart though, I highly recommend you have a decent linux background, or be very patient and use it as a learning tool ![]() Hdhomerun's don't work without the beta version also just an fyi, and some plugins don't. Netflix plugin which I really wanted doesn't work due to DRM, you must be running windows MCE for it. |
From the FAQ on the HD-PVR it doesn't look like it will work with linux at least until Hauppauge provides drivers anyway.
Edit: Looks like drivers are coming soon see here. Last edited by BobPhoenix; 06-03-2008 at 07:03 AM. Reason: Add driver correction. |
My CentOS server setup using these steps
http://forums.sagetv.com/forums/showthread.php?t=29968 is working without a single issue since it was setup, but I do not use it for any TV related activities. The server is Dell PowerEdge 600SC (P42.4GHz with 1GB or memory) I have 3 software RAID arrays. RAID1: 1st is OS and 2nd is Data both on 2 x 500GB WD SATA|| disks with Promise SATA controller. RAID5 is 4 x 200 GB Maxtor ATA133 disks with Promise ATA133 controller. The advantage for me were 1. Completely free (I do have access to all Windows Servers but I still prefer to use the free CentOS) 2. Software RAID works extremely well even for System partition (wasn't possible with W23k as far as my reasearch can tell me) 3. Windows file sharing works for my Windows XP clients much better with Samba then it worked with W23k which was used on this server for 2+ years before. 4. I love to have the ability to have multiple SageTV versions installed and change the one I use only with a change of symlink. Last edited by bastafidli; 06-02-2008 at 02:37 PM. |
I've been running a SageTV server on Ubuntu linux for almost a year now. I have an HD extender and a mvp client. I only run a single tuner on the Server, since Sage's PVR functions isn't my primary reason for using Sage. I do record stuff using Sage, but I have a expressVu dual tuner HD pvr, and that unit is my main Unit. I don't have any drawbacks about running Sage under Linux... Although, the fact that the Hauppauge HD PVR doesn't have native linux support will be a drawback... but not enough to make me switch.
I run a Ubuntu Linux server at home.
I made the switch from Windows to Linux. And the most compelling reason to do so is better run time with known working drivers. If you're not on the bleeding edge, the box will just keep running.
I have ordered a HD-PVR, will be here tomorrow, and I will be setting it up on my old windows server license to act as a network encoder to my linux server. I am also switching from DirecTV to FiOS on Saturday and it will be my first foray into Lirc. If I get really ambitious, I may tackle the idea of running it in vmware as well. FWIW - As of Saturday I will be running 3 HVR-1600s (Analog and QAM), 1 HVR-1800 (May pull, still undecided; QAM only), 1 HD-PVR (Windows Network encoder) The network encoder is untested by SageTV with the HD-PVR, but they are willing to work with me on it. B
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
I have two SageTV setups running under Linux.
At my mom's house, I have Ubuntu 7.04 with 3 MVPs, a PVR 150 and a PVR 250. This was installed over a year ago and she (almost 80) has no issues with it. At my apartment, I just installed a base (X-less) Debian install with XFS, an HDHR and an HD Extender. This was a little tougher, but using the beta for SageTV and the HD Extender, everything is working well. I wouldn't recommend this setup for everyone as there is no GUI and the setup might need some compiling (lirc, etc), but since my server is underpowered, every little saving helps. Ubuntu, Mandriva, etc would be easier. The HD-PVR won't be supported by Hauppauge on Linux (at least initially), but according to the gossip on the MythTV site, the community is working on getting it working under Linux. Since the other Hauppauge equipment is community written (ivtv), I don't doubt that it will be running under Linux.
Server - AMD 4850e, ASUS M3A76-CM, 4GB RAM, 1.5TB drive OS - ArchLinux - console only Client(s) - Media MVP Tuner(s) - 2x HVR 1600 (SD only) |
Hey, Sage CTO is on Linux, hopefully that will mean that in the future Sage will be more Linux friendly
Some small suggestions |
I originally tried SageTV on Gentoo, and had a lot of problems. I think it's more of an issue with Gentoo than with SageTV. It's hard to keep Gentoo up-to-date, and unmasking packages is a slippery slope.
I switched to Ubuntu sometime last fall. I never have been able to get lirc to work with either the Hauppauge receiver or USB-UIRT. I ended up moving the server into the den and occasionally watched TV on the computer screen in there. I'm glad they released the HD extender, I can now use Sage on the plasma TV again ![]() Bottom line: I use the Linux version on my server and a placeshifter license on my Linux laptop. I have the HD extender hooked up to the TV.
Server: Intel Core i5 760 Quad, Gigabyte GA-H57M-USB3, 4GB RAM, Gigabyte GeForce 210, 120GB SSD (OS), 1TB SATA, HD HomeRun. Extender: STP-HD300, Harmony 550 Remote, Netgear MCA1001 Ethernet over Coax. SageTV: SageTV Server 7.1.8 on Ubuntu Linux 11.04, SageTV Placeshifter for Mac 6.6.2, SageTV Client 7.0.15 for Windows, Linux Placeshifter 7.1.8 on Server and Client, Java 1.6. Plugins: Jetty, Nielm's Web Server, Mobile Web Interface. |
I have a Ubuntu Server that has been working great for over a year on Charter cable TV. I am now making the switch to Directv with HDPVR's, which due to the lack of drivers, I will be setting this up with VMware Server 2.0 and use my Windows license as a network encoder. I just got charged for one my boxes so I am hoping to get things going this weekend if it arrives in time.
ESXi Host Intel Xeon x3440 on Intel S3420PLX, 4GB RAM, 80GB Primary Server:2 CPU's and 2GB memory Allocated, 15GB Virtual Primary, 1.5 TB RDM Physical Disk, A180 using VMDirectPath, 1 xHDHR Headless ArchLinux 2.6.34 64-bit, SageTV 7.0.15 Sun JRE 1.6.0_20 Comskip&PlayonWindows XP 2CPU and 1GB Ram Allocated Clients: 1 Media MVP and 2 STX-HD100 |
Do you guys who use linux as a pvr leave the system on 24-7 or does sagetv wakeup the system for scheduled recordings?
Thanks!! |
I leave my server on 24/7
HD Media Extender does not find Server | HiDefDon | SageTV Media Extender | 25 | 11-10-2008 08:55 AM |
Linux Edition and Media Extender | matt.simpson | SageTV Linux | 7 | 01-05-2008 08:33 AM |
SageTV Announces Support for AMD LIVE!(TM) Home Cinema and Home Media Server | Narflex | Announcements | 0 | 01-10-2007 09:09 AM |
How to get a server up and running | cbhatt | SageTV Linux | 0 | 01-21-2006 08:39 AM |
