Old 05-28-2009, 01:32 PM
LookitsErin LookitsErin is offline
SageTV License in Hauppauge HD-PVR & SageTV Media Center for Windows Bundle
Anyone know what version of SageTv comes standard with this bundle?? 6.5?
Old 05-28-2009, 01:38 PM
Any SageTV server license purchased right now is a v6.x license, which can be used with any version of SageTV released after v6.0 so far.
Old 05-28-2009, 01:43 PM
Thanks for the quick reply, Andy!
One more obvious question for you, SageTv Client 6.5 will work perfect with that bundle purchase?
Also, with the PVR, will I be able to view the show live and record it at the same time, or will that require an additional tuner card purchase?
Thanks so much for you're help. I am under a deadline to get this info out...
Old 05-28-2009, 01:52 PM
TechBill's Avatar
TechBill TechBill is offline
You will be able to record and view the same live show but if you want to view a live show and still record a different show at the same time then you will need additional tuners to do that.
My HTPC have 2 tuners connected to 2 DirectTV ird boxes so I could view one live show while it record a different show at the same time.
I have though about adding 1 more tuner but I have not yet encounter to where I needed to have a 3rd tuner added because many network station now days repeat the same show 2-3 hours later so if both of my tuners are in used recording shows and there a 3rd show that I like to watch then SageTV will recorded the 3rd show in 2 hours later when it is repeated again on the network.
Bill
HTPC System
Media Extenders
HD300
HTPC Software
Old 05-28-2009, 02:16 PM
Yes.
Just so you know: live TV in SageTV is simply a recording that you happen to watch while it is recording.
There is a PDF manual installed with SageTV (and available as a separate download); you may want to check out the "Watching Live TV" section (p. 21) of chapter 2's Quick Start Guide.
Considering buying SageTV w/ Media Center license, playback question joihan77 SageTV HD Theater - Media Player 10 04-22-2009 12:37 PM
SageTV: PVR vs. Media Center jimwhite General Discussion 22 01-11-2009 07:02 AM
Hauppauge Remote Opens Media Center instead of SageTV grendell2099 Hardware Support 0 09-09-2008 04:23 PM
SageTV Media Center for Windows Version 6 Upgrade zazz SageTV Software 1 05-28-2008 08:09 PM
SageTV Media Center Software for Windows Now Available for Linux dkardatzke Announcements 0 01-06-2005 09:56 AM
