Old 03-10-2004, 09:11 AM
ckron's Avatar
ckron ckron is offline
Hauppauge Driver Version
I downloaded the latest driver from Hauppauge's website and installed them as per their instructions. It looks they were a base of 22029 and an update to 22037. When I was finished, Device manager still reported a version 22029. Is that right? I don't think so.
Christopher Kron MCP, CNA
ATI 9100 chipset
P4 2.4GHz
PVR-350
PVR-150
ATI Radeon 9100
512MB DDR RAM
2 x 80GB HDD
MediaMVP
Old 03-10-2004, 10:01 AM
SHS's Avatar
SHS SHS is offline
Yes that rigth
Old 03-10-2004, 10:07 AM
ckron's Avatar
Originally posted by SHS
Yes that rigth
Thanks for the reply, but why doesn't that make any sense to me. How is one supposed to know what driver version they are actually using when Device manager does not correctly report it?
Especially when you see many posts about needing to use a specific version. I have that annoying OSD on PVR-350 problem. I specifically purchased SageTV for this ability and would like to see it working.
Sorry, I am just frustrated. I really love the video quality from the output of the 350 and I like SageTV alot. It was reassuring to see how active these forums are.
ATI 9100 chipset
P4 2.4GHz
PVR-350
PVR-150
ATI Radeon 9100
512MB DDR RAM
2 x 80GB HDD
MediaMVP
Old 03-10-2004, 11:02 AM
SHS's Avatar
SHS SHS is offline
Becuase the drivers don't update all with the same ver number most of the time they just update one or more file which in turn change the ver to something like 22037 or one higher which this case was hcwFRead.ax, HCWTVWND.dll and HCWFWrit.ax
