Old 10-31-2010, 07:46 AM
derfel derfel is offline
HD-PVR driver version
Hi,
Which version of the HD-PVR driver do you recommend using? I've been using 301 for a while now but should I upgrade to the latest version? Does version 7 "interact" better with a newer version of the driver? Is it more stable?
Thanks.
Old 10-31-2010, 05:11 PM
SDeGonge's Avatar
SDeGonge SDeGonge is offline
Many will recommend the 301 driver but I've been using 1.5.7.0 for a while so far with no problems. I haven't had an HDPVR problem in months (knock on wood). Prior to that I was having many problems. I stopped using the optical, updated the drivers, and started rebooting my system daily. Don't know what fixed it for me but I'm not going to mess around trying to figure it out.
SageTV User Since 2009
Server Hardware: AMD FX6100, 6 Cores, 3.3GHz, 8GB RAM, TA970XE MB, 3TB HD, HVR-2250, HD-PVR, nVidia 9600GT 512MB
Server Software: SageTV 9, Windows 10 64bit, EventGhost
Client Hardware: HD200 x2, INT-422-3 & WR7 Remote
Service Provider: Cablevision (QAM to 2250, SamsungBox to HDPVR)
Old 10-31-2010, 07:36 PM
Diego Garcia Diego Garcia is offline
Do you automatically reboot the server every day, or do it manually? I've toyed with trying to reboot my server automatically, but I don't know how to do it in a way which won't potentially interfere with a scheduled recording.
Old 10-31-2010, 07:41 PM
Wish I could say the same. 1 day after upgrading to SageTV 7 and the 1.5.7.0 driver I got a lockup and my recording wouldn't stop until I restarted the computer. The next thing I'm going to try is a separate USB controller installed in a PCI slot with a NEC controller. I had this same thing happen with SageTV 6.6 and the first 5.1 Happauge driver. I'm not going to drop back to pre-5.1 drivers or use stereo inputs because the lockups don't happen often. Just when a show doesn't have a repeat!
Old 11-01-2010, 08:29 AM
Skirge01's Avatar
Skirge01 Skirge01 is offline
Bob, I meant to reply with this question in my DirecTV thread, but since you reminded me here... did you run the HCWclear.exe file and then install the latest drivers?
To stay on topic, I'm running the latest drivers and have never had an issue with them. I was a long time holdout of the .301 drivers, too.
Software: SageTV 7
Old 11-01-2010, 09:12 AM
I don't really remember but I will do that tonight if I have a window.
Old 11-01-2010, 12:12 PM
SDeGonge's Avatar
I automatically reboot every morning at 4am. 99 times out of 100 there is nothing recording at that time. I've thought about using SQJ to make my reboots a little smarter (only allow if no activity) but just haven't got to it yet.
Old 11-01-2010, 12:46 PM
jerryt jerryt is offline
My server recycles the HDPVRs power at 3:00 AM, by 3:01 they are back on line.
SERVER: Win 7 x64/i7-860/Zotac H55ITX-C-E/Corsair H70/CFI a7879 case/12 TB Pooled with Drive Bender. DVBLogic: streaming HDPVR content to SageTV, WMC Clients, NPVR Clients, Remote Computers & iphone. 2ea HDPVR, 3ea HDHomeRun, 2ea VIP211
Old 11-01-2010, 12:49 PM
Helheim Helheim is offline
How are you recycling them?
Old 11-01-2010, 01:28 PM
IP controled power switch. But a Stanley timer P/N 38424 would be simplier, see;
http://dvblogic.com/phpBB3/viewtopic.php?t=11211
Old 11-01-2010, 01:57 PM
macsupergeek macsupergeek is offline
I setup a new server running windows 7 64bit and sage 7 with 2 x HDPVRs running version 1.5.7 -- total uptime is going on 30 days 17 hours, no reboots and no hiccups with my HDPVRs. I would say I average at least 4 - 1 hour programs on them daily, not including live TV as they are needed for my STBs and digital channels. So I would say that windows 7 and sage 7 treat HDPVRs quite well indeed.
SERVER: Dual Core Xeon 3.0GHz 5160, 8gb RAM, Win7 x64, SageTV 9.0.13.536 w/ BMT, WebUI, OpenDCT, Java 1.70_79
TUNERS: 2 x Ceton PCIe InfinitiTV - FIOS
STORAGE: UNRAID - 8tb for archived shows, DVDs, pictures and music
CLIENTS: 2 x HD200s, 2 x HD300
Old 11-01-2010, 02:04 PM
And that may be another option for me since I'm still on WinXP pro. "If it ain't broke don't fix it". But maybe it is broke!
Old 11-01-2010, 02:05 PM
I'm running the 1.0.5.301's and haven't had a lockup in months.
Old 11-01-2010, 02:59 PM
call hauppauge, even if you're out of warranty. they tested mine somehow, it failed a lot, and they replaced it about six weeks ago. One freeze since then, and it happened during a reboot. running win7, sage7, and the latest drivers.
there, i taunted the hdpvr gods. tonight i will go home and my hdpvr will be a charred hole in the shelf.
Old 11-01-2010, 09:32 PM
inskeepp inskeepp is offline
I've been having problems in the later 7.0.x betas. I been trying 1.5.7 and 1.5.6.1. It was rock solid in earlier betas and V6. It's not locking up completely but I'm getting a few pauses in a half hour show. It's in the recording. I see the light go off and the pauses are there no matter what I play back the recording with.
HD PVR driver version 1.5.7.0 bcjenkins Hardware Support 53 08-25-2010 08:47 PM
HD PVR Driver Version bsung SageTV Beta Test Software 3 05-21-2010 11:56 AM
Hauppauge PVR-250 Driver version question Steerpike Hardware Support 2 07-19-2007 11:20 PM
Q: Current PVR-350 driver version? shatter Hardware Support 2 06-07-2005 03:39 AM
Hauppauge Driver Version ckron SageTV Beta Test Software 3 03-10-2004 11:02 AM
