Old 04-14-2008, 09:06 AM
Slipshod's Avatar
Slipshod Slipshod is offline
Java update on WHS version of Sage?
My new WHS install is still on the "1.6.0" (exact string from sys info) version of Java, and I don't see a clear way to update it. The last server was on something like "1.6.0_5" Java, and Java would automatically detect and offer to install new updates.
1. Is the WHS version of sage bound to a specific version of Java?
2. Is it possible, or safe, to update the version of Java used by the WHS version of Sage?
SageTV V7 (WHS), Diamond UI
Server: WHS with Xeon X3350, 4GB ECC, ASUS P5BV-C/4L, recording into a 6.6TB Drive pool
Tuners: 4 (2x HDHR)
Clients: 2x HD300, 1x HD200 Extenders, 1x Placeshifter
2x Roku XD
Old 04-14-2008, 09:16 AM
It's Windows and shouldn't matter. I just did my swing over to WHS this weekend and installed the 1.6.0_5 version and all is well. You can still go to the WHS desktop and through control panel set java to update automatically or do it manually. Just remember to uninstall the previous version.
Old 04-14-2008, 09:23 AM
Motofreak75 Motofreak75 is offline
Send a message via ICQ to Motofreak75
in thesage folder is a java directory (JRE) . that is the java directory unless you install the latest from Sunmicro itself. Personal I found java version that comes with WHS is stable and I dont see a need to upgrade.
I how ever did some testing and renamed the 1.6 jre folder and moved in 1.6.5 and play with sage a bit. but I notced and the wife did, that all of my stx's locked up several times and after 2 hours I restored the original jre folder and so far one of my stx units have only locked up once in the pass 3 weeks since using the 1.6 jre folder.
Let us know how your WHS behaves please.
thanks
12.04 server Sagetv7
HD-pvr / 2250 /PVR 500 / DVBS w/rotor & 36 inch dish
Old 04-14-2008, 10:01 AM
Java doesn't come with WHS. Java is installed by the Sage application if it is not found on the server. And it's all from Sun.
Old 04-14-2008, 01:03 PM
when you install sage WHS version, Sage puts a copy of 1.6.0 in the sage directory so there was no need for installing Java to get it up and running for me.
That all that I did and its very stable for me so far.
New setup - WHS R5000 HD100 - No Video mediahome SageTV Software 2 12-15-2007 03:00 AM
I don't understand Java version stuff... garyellis SageTV Software 8 07-30-2007 06:12 AM
Broken Server Java Version Steve52 SageTV Software 5 03-14-2007 04:40 PM
getting sage to play a playlist xlr8shun SageTV Software 4 05-19-2006 12:53 PM
Sage crashes rfutscher SageTV Software 0 01-23-2006 04:31 PM
