Old 12-01-2010, 09:01 AM
KKnox KKnox is offline
Which version of Java is bundled with Sage V7?
Immediately after installing Sage 7 (on Windows 7) my MVP extender was working well, but after upgrading Java to the latest version (6.22) the UI on the extender is very slow. Looking at the log I see a lot of this:
Tue 11/30 19:47:44.719 [FinalRender-000dfe0c441e@1ff8cef] MiniUI client error11:java.io.IOException: An existing connection was forcibly closed by the remote host
Tue 11/30 19:47:44.720 [FinalRender-000dfe0c441e@1ff8cef] java.io.IOException: An existing connection was forcibly closed by the remote host
I don't know of this is normal but it makes me think I need to downgrade my Java to an earlier version. I'd like to go back to the version that installed along with Sage 7 but I don't know what that was. Can anyone tell me?
I do have an HD300 arriving on Friday to replace the MVP. I hope that either the Java downgrade or the MVP-to-HD300 upgrade solves the extender sluggishness.
Thanks. Kevin
Old 12-01-2010, 09:32 AM
PiX64's Avatar
PiX64 PiX64 is offline
6u10 at least that is waht was bundled with mine that i just installed after my long fiasco this past weekend. 6u10
Old 12-01-2010, 10:42 AM
Thanks. I'll install it tonight and see if it makes any difference.
Old 12-01-2010, 02:06 PM
PiX64's Avatar
i had the same issue with win 7. I have a thread that i started which is a step by step of my weekend and everything i tried. check it out it may help you.
in the end i ended up bombing back to win xp pro sp3.
http://forums.sagetv.com/forums/showthread.php?t=52620
Old 12-04-2010, 11:31 AM
I installed the older version of Java (6u10) to no avail. The MVP UI was still very slow over a wireless G network using a bridge on the MVP end. The MVP would play recordings fine, but the UI was painfully slow. (It was much better when I ran a 100 ft ethernet cable down the stairs to the family room.) However, I connected my new HD300 over the same wireless network last night and its UI is lightning fast.
The WAF is better than ever now.
How to force Sage to use a newer version of Java? rsteele SageTV Software 7 12-18-2015 12:22 PM
What version of Java garmpe SageTV Software 2 06-04-2008 08:08 AM
Java update on WHS version of Sage? Slipshod SageTV Software 4 04-14-2008 01:03 PM
Which Java version is stable with which SageTV version? reboot_this SageTV Software 2 04-27-2007 06:17 AM
Best version of java for dedicated Sage server? blade SageTV Software 2 09-22-2006 01:11 PM
