Old 12-09-2006, 03:03 PM
Box8489 Box8489 is offline
Send a message via MSN to Box8489
Do I have a Java problem ?
Hi again,
I'm sorry to disturb you experts again, but I really want to learn more about Linux so I have installed a Fedora Core 6 to play with. (learned a lot already )
I have also installed SageTV without any obvious problems.
But when I start my Client from an Windows pc, he detects the server but says: "An exception occurred in Java: Java.lang.NullPointerException".
When I start my Linux Client at the same machine where the server is running, is the GUI completely empty.
Any idea of in which direction I should look for the problem?
Regards:
Michael
Old 12-09-2006, 04:10 PM
joat joat is offline
Missing Java or path?
I had similar errors when I didn't have the path set for the JRE. Assuming that you have IVTV (or whatever it is that you use to encode) installed properly:
1) Grab the latest JRE from java.sun.com (it might be called JSE-something).
2) Run it in your home directory. It'll create a directory called "jre-something". For simplicity, rename it to "jre"
3) Edit your .bashrc to include "export PATH=/home/yourhomedir/jre/bin:$PATH'
4) If you run the server as root, repeat step #3 for the root .bashrc
5) Try running the server and client again
- joat
Old 12-09-2006, 05:19 PM
Hi joat,
Thank U so much.... that was it, fantastic..
Now I can move on to the next challenges
Regards:
Michael
Old 02-17-2007, 06:53 PM
No problem
No problem. Uh, is it me or is the clock/calendar for these posts a bit screwy?
