Old 05-17-2007, 02:03 PM
Axeman Axeman is offline
Disk usage bar problem
About 2 weeks ago I upgraded from 6.0.19 to 6.1.9. I turned on the disk usage bar that displays at the top of the screen when I did the upgrade. Last week I rebooted after installing some Windows updates from MS.
After the reboot my some of my remote control buttons didn't work and the disk usage bar now shows 0 disk space usage when I am on the Sage Recordings page, the guide or the Scheduled Recordings page. If I am on other menu pages it displays correctly.
I had to go in an link the remote commands with Sage again. No big deal but strange. I haven't been able to fix the disk usage bar though. I even did a full uninstall and reinstall today (keeping sage.properties, wiz.bin and wiz.bak) and it still doesn't work correctly. Any ideas?
I'm am running the dynamic menu .stv, could this be causing problems?
Edit: After looking at sage again, the bar reports 0 free space not 0 usage as I stated above.
Weird Playback Problem Taddeusz SageTV Software 2 08-05-2006 07:08 PM
Having a problem with stuttering playback. Is my HW good enough? J_P Hardware Support 4 02-04-2006 06:45 AM
Disk space bar accuracy with HDTV files? jbuszkie SageTV Customizations 5 12-12-2005 06:02 PM
Disk Space Bar Suggestion Truxton SageTV Customizations 4 12-04-2004 02:48 PM
Problem with progress bar and Sage Client ldavis SageTV Software 3 04-05-2004 08:48 PM
