Old 11-11-2007, 07:40 PM
cenwesi cenwesi is offline
How many people use SageTV Media Center for Linux?
I am currious as to how many people here use SageTV Media Center for Linux?
Old 11-12-2007, 04:58 PM
41 views and not one person using it?
Old 11-12-2007, 05:15 PM
Fluffdaddy Fluffdaddy is offline
This does not surprise me.
I mean how popular is Linux........really?
Old 11-12-2007, 07:04 PM
PGPfan's Avatar
PGPfan PGPfan is offline
I agree completely. I have a Linux based server (UnRaid) yet there's just no compelling reason for me to look into it as a desktop replacement, let alone as the basis for a Sage system. Too much of a pain to setup/maintain..
-PGPfan
Sage Server: Gigabyte 690AMD m-ATX, Athlon II X4 620 Propus, 3.0 GB ram, (1) VistaView dual analog PCI-e tuner, (2) Avermedia Purity 3D MCE 250's, (1) HD-Homerun, 1.5 TB of hard drives in a Windows Home Server drive pool, Western Digital 300GB 'scratch' disk outside the pool, Gigabit LAN
Sage Clients: MSI DIVA m-ATX, 5.1 channel 100w/channel amplifier card, 2 GB ram, , (1) Hauppauge MVP, (1) SageTV HD-100 Media Storage: unRAID 3.6TB server
Old 11-12-2007, 07:34 PM
I will take it you two haven't played with linux lately.
Old 11-12-2007, 08:04 PM
I don't know, I switched from SageTV on Windows to SageTV on Linux. I run 4 SD tuners and 2 HD tuners in one box. One is doing QAM the other is OTA.
Personally, I find the linux boxen to be much more stable with hd tuners
b
Old 11-12-2007, 08:09 PM
What OS are you running? Gentoo or Ubuntu....
Old 11-12-2007, 08:22 PM
arch linux
started with gentoo, switched to ubuntu, then settled on arch. I was mostly impressed with the install size and their package manager is pretty easy to build your own and is quite powerful.
B
Old 11-12-2007, 10:58 PM
jpwegas jpwegas is offline
As a desktop replacement I won't necessarily disagree with you (although Ubuntu's desktop distro is evolving quote nicely - I was honestly surprised last time I played around with it).
As far as setup/maintenance, the OS level pains partly depend on what each person is familiar with. I'm a Mac and Unix guy so I would be completely lost trying to run Sage on Windows.
My Sage server (Ubuntu) box sits in the basement and runs pretty well (5 tuners - 1 HD, 3 Analog, 1 Analog via STB). My remote clients are MVPs or Placeshifter clients.
Installing Sage on Ubuntu was pretty straightforward. My Hauppauge cards and HD card were recognized without having to do anything special. (Although I did have to suppress the detection of a "phantom" analog card on the HD PCI tuner.)
My pain points for running Sage on Linux (so far) have been:
  • Sage bugs specific to Linux. (Which are addressed fairly quickly by Sage when reported.)
  • Difficult to get IR output working for STB control. (There are lots of hardware options, and the details on how to do it all can be confusing.)
--John
Old 11-13-2007, 07:33 AM
Thanks jpwegas. I plan on running Ubuntu Desktop v7.10 (Gusty). I currently use Ubuntu Server (64bit) for my Nas/VMware. I was also surprised when i tried Ubuntu how far linux/unix system has come along since the last time i tried it. I used the liveCD even on an OLD pc and it recognized everything and worked without asking about this hardware and what not. It is even much easier these days setting up a linux box as opposed to 5-8yrs ago. Anyway currently with my SageTV Media Center (windows) i reboot the box every night so sage doesn't act weired everything i have to use it... Long story.
Old 11-14-2007, 07:50 AM
ntisdale ntisdale is offline
To add my two cents...started off as a linux n00b (well near enough - I knew the 'ls' command) and installed SageTV on Gentoo using Sage's instructions over a year ago. The server powers two extenders and one windows client and i rarely reboot it. I've had my share of linux issues and sage issues but I've managed to fix the linux ones after searching the net and the sage issues tend to be during beta releases - sage support have always been very fast in fixing them when reported. The key to linux is stick with hardware that is well supported by your distro of choice.
All in all I'm very happy with my SageTV linux box! Good work sage!
Neil
Old 11-14-2007, 08:29 AM
Ok, i got it installed and and i am somewhat lost. Installed fine and i tested out the Plashshifter client which worked. What i am missing here is the way my windows box is currently setup. PC boots and SageTV comes up. On my Ubuntu box i do not see the gui for sage. The placeshifter connects and i am able to set things up but of course that is for the placeshifter setting.
PS, this linux box is strickly for Sage. I don not need the desktop or what not. I can handle the NAS/Samba stuff, but one thing at a time. How do i get the gui up when i boot up the Linux box?
Old 11-14-2007, 11:51 AM
I'm not sure if this answers your questions or not, but:
When you use Placeshifter to first connect to the server, it will initially ask you some setup questions. There is also a Setup menu from the main Sage interface. Many of the options under Sage's "Setup" menu are actually server specific configuration settings.
For example, I can configure the video capture devices on my server using the PS client on my Mac.
It can sometimes be confusing whether a setting is for the client or the server, but you can configure the server using the PS client.
--John
Old 11-14-2007, 12:38 PM
That is what happened when i ran my placeshifter on my windows box against the server and configured things. Now how do i get the server to display SageTV. Keep in mind that i want my current PC once the OS is done booting to show the SageTV screen like my current XP box does. I have my wiz.bin backed up and my movies/recordings are on my other Ubuntu server.
Old 11-15-2007, 02:11 PM
Sorry, I'm a little confused.
You want to run a copy of the Sage GUI on the Sage server? - i.e. your Ubuntu box to act as both a Sage server (to record, etc) and Sage client (to view)?
--John
Old 11-15-2007, 08:44 PM
Exactly, basically my PC boots up, the SageTVServiceControl.exe runs and then the SageTv.exe runs, which is the gui.
I should also mention that all my recordings and movies are on my Ubuntu Server (samba) box.
I am kind of surprise that not too many people are charming in as to how they have their stuff setup.
Old 11-16-2007, 11:30 AM
I run Sage under linux on my Ubuntu server. I use the MVP to watch tv because i don't want a computer in the main room. Works great. the MVP was really the defining thing that made me want to use a commercial product like sage over mythtv, mediaportal, etc.
I'm using a DVB-S setup, which sage doesn't support that well in linux or windows. But in linux, I was able to get dvb-s working in Sage by writing a sage compatible network encoder. Still a work in progress. Channel changing is a little slow, but that's not sage's fault. I working on updating the viewable channels in the guide based on what the network encoder has scanned. I wouldn't exactly say it's production strength, but it's a fun project
I'm not sure sage really wants to have linux users to be honest. If you are considering going Linux, then you have to shell out the money right away. There is no trial period. I think that in itself would deter most people. Fortunately for me, I know a couple of other people that are running the sage linux version, so I was able to see it first hand before buying it. I don't have any regrets.
If you are considering going Linux, be aware that most sage users are windows users, and if they write plugins, it's hit or miss that they will run under linux. I've run into that a couple of times so far.
Old 11-16-2007, 11:39 AM
One thing to note:
There are several types of SageTV "clients". The Sage TV Client (available for Windows and Mac), Placeshifter (available for Windows, Mac and Linux) and Media MVPs (aka "SageTV Media Extenders" - standalone hardware). If you have ripped DVDs as VOBs (you mentioned "movies", but I didn't know what format) on your server, the Placeshifter client will not play them.
If you are using the Ubuntu box as a server and a client, the only Sage client that is available is Placeshifter.
In order to have Placeshifter start up automatically, you need to set up a user to auto-login when the machine boots. There are some examples on how to do this on the MythTV wiki. Note that you have to have some minimal window manager running, since X must be running for Placeshifter to run.
Then just add the startsage script to the .cshrc or .bashrc or whatever shell your Sage user uses.
Just for reference, my setup is:
  • Sage server running on Ubunut 7.04 (server only, no client).
    • 3x analog cable tuners
    • 1x analog input from external STB
    • 1x HD tuner card
  • Media MVP for main TV
  • Media MVP for bedroom TV (not done yet)
  • Occasionally I use Placeshifter from my Mac when I am configuring things
I didn't want a large (and loud) box in the main TV room, so my server sits in the basement. The MVPs are completely silent.
--John
Old 11-16-2007, 11:53 AM
Ditto here. Someone I know was able to show me Sage so I didn't have any issues with there not being a trial period. Although I agree that they could probably sell more if they had a Linux trial period.
I will note two additional things:
When the plugin problem was not related to an external Windows dependency (for example, not adjusting paths used by a plugin so they get automatically corrected regardless the platform), I've brought it up to the plugin developer and it's been updated.
Sage support has always been responsive to my support questions. I don't feel like as a Linux user I'm treated as a "second class" citizen. Occasionally the response I get is Windows specific but when I say "oh, I'm on Linux" they still give me an updated answer.
Many Sage issues (scheduling issues for example) have nothing to do with the platform (since the core Sage server is basically the same) so don't be afraid to report problems just because you are running Linux.
--John
Old 11-16-2007, 03:46 PM
Originally Posted by jpwegas View Post
One thing to note:
Yeah and it really suck, good thing right now is i don't have any ripped DVD's anymore. I converted them over to Divx.
Yep, so far that is what i got from people here and i have it working. Next on my list of things to do is the remote.
    • 1x HD tuner card
--John
I pretty much did that, but client/server is a shuttle xpc and it very quite.
SageTV for Macintosh V6.2 is Released! Narflex Announcements 0 06-26-2007 10:52 AM
Vista Media Center jayrbrown77 General Discussion 21 01-27-2007 09:29 AM
SageTv Media Center and Client on the same PC jesse_breaker SageTV Media Extender 1 07-04-2006 01:38 PM
SageTV Wireless Media Extender Now Available! Narflex Announcements 0 05-31-2006 06:00 PM
