Old 08-09-2010, 09:23 PM
SageTV Gadget
Should this work in Sage7? I seem to have everything set up correctly but I get the NA-Check network connection, etc. message.
But when I click in the logo it actually does launch the Sage web interface in my browser so I would think that my settings are correct.
Old 08-10-2010, 08:32 AM
Did you configure the user name and password correctly? If you did a default jetty install for the webserver it is sage and frey. Also check your firewall. Mine is working fine in Sage7.
Old 08-10-2010, 11:38 AM
I changed the user/password to my own settings and updated them in the Gadget - but I really do think this is somehow related to passwords. Would I get an error in a log file somewhere?
This is really weird since everything is the same between the two servers, except servername and port. And externally I have mapped the V6 server to port 8081 and the V7 server to port 8080. Since you can use external servernames in the Gadget I really should be able to keep the servername at server.dynalias.com just be able to change the port from 8081 to 8080 and have it work.
This works in my web browser where I can switch the URL from http://server.dynalias.com:8081/sage/Home to http://server.dynalias.com:8080/sage/Home and get into the web server without problems.
Utility: Vista Sidebar Gadget cncb SageTV Customizations 171 02-24-2011 07:47 PM
SageTV Vista Gadget HDOnly SageTV Customizations 7 11-25-2009 08:39 AM
Anyone used a gadget like this? pjpjpjpj Hardware Support 4 09-30-2009 02:05 PM
Any way to view SageTV as a sidebar gadget? SAGEaustin General Discussion 6 10-17-2007 07:56 PM
