Old 05-11-2018, 09:12 AM
gdippel gdippel is offline
problem with Placeshifter SOLVED
I've installed my SageTV server on my Ubuntu VM as I described in another post. Now I can't seem to get Placeshifter on another Ubuntu box to work. I've had this Placeshifter working when I had the server on a windows PC so I'm sure it's a configuration problem on the server side. I have Placeshifter and client connections enabled but despite connecting and loading the GUI, no video either live streaming or recorded will play. Placeshifter is on a local network. Is there any configurable settings in Sage properties on the server side I should check?
Update: I am able to connect with Placeshifter from my windows PC so it may be a problem with Placeshifter on my Ubuntu box after all. There were some recent updates which were installed. Possibly they are the culprits.
Solved: Chose Dynamic streaming and now Placeshifter works.
Placeshifter connection problem hb4 SageTV Placeshifter 19 10-13-2016 07:43 PM
Testing Placeshifter connection problem? hugo69 SageTV Placeshifter 15 10-26-2013 12:30 PM
Placeshifter MAC address problem zoundz SageTV Placeshifter 0 04-11-2009 07:37 PM
Placeshifter streaming problem chrysek SageTV Placeshifter 18 05-22-2006 01:39 PM
Placeshifter Problem on Pal Videos garystein SageTV Beta Test Software 0 02-21-2006 06:20 PM
