Old 04-14-2011, 04:10 PM
Lostinpvr's Avatar
Lostinpvr Lostinpvr is offline
No longer able to change channels via USB-UIRT?
I seem to have a new issue with my setup, with changing channels.
All was working correctly until 2 hours ago and then all of a sudden SageTV would no longer change channels. I noticed in SETUP if you goto "Setup Video Sources" and select a tuner then goto "Tuner Control" then select "Change Tuning Device" there are no tuners listed. I checked to see if the .Ir files got deleted or something and they did not! Configuration did not change so at this point i am totally lost
Any Ideas here?
Thanks Jeff
Sage Ver:SageTv 7.19.256 | Server:Intel DH55HC/i5 650 3.20GHz OS:W7P | Storage: 3 TB | Client's:HD200, HD300, 1-MVP, PS | Capture:2-HVR1600, 1-HD-PVR | STB:1-HD 2-SD | 2-USB-UIRT
Old 04-27-2011, 09:16 PM
rhmillett rhmillett is offline
Same here
I am having the same problem. Rebooting the computer brings it back, but it hasn't been lasting very long today.
SageTV7/USB-UIRT: Can't change channels on cable box peptide Hardware Support 4 02-27-2011 12:37 PM
USB Uirt no longer needed? heffneil Hardware Support 2 01-03-2011 05:15 PM
one USB-UIRT to change STB/DTA channels and control Sage PolloLoco Hardware Support 1 01-03-2010 07:31 AM
Can't get USB-UIRT to change channels nettech_gt Hardware Support 5 08-26-2007 12:48 AM
3.0.11 no longer changing channels with USB-UIRT CanadianEh SageTV Beta Test Software 1 10-02-2005 04:39 PM
