Old 04-09-2007, 10:14 AM
ässo ässo is offline
MVP with 6.1.8 hangs when playing music
Hi,
6.1.8 hangs the SageTV Service when trying to play music on my MVP.
Any suggestions?
/Ässo
Old 04-09-2007, 11:35 AM
It is Media Center/Music (or any audio of course). I have XP Home with all latest updates and the latest Java.
Everything else seem to run perfectly and I have not experienced this problem earlier.
/Ässo
Old 04-09-2007, 11:52 AM
When you upgraded to v6.1, did you unplug the MVP, wait for several seconds, then plug it in again before trying to use it?
You could try deleting the MVP's properties file in the 'clients' subdir in the SageTV install dir.
Old 04-09-2007, 01:01 PM
I have two MVPs and one was connected but the SageTV Service was stopped.
First I did as you suggested and deleted the clients/properties files with no luck.
Then I re-installed SageTV with both MVPs disconnected. Still no luck.
It seems that all Play lists including the Now Playing list stops working. I have managed to start a single audio file but if I select one more the GUI says it is added to the Now Playing list. After that I have never been able to play an audio file using MVP extender and software 6.1.8.
My SageTV GUI on my computer running the SageTV Service has not these problems.
/Ässo
Old 04-09-2007, 02:06 PM
Maybe someone else will have a suggestion if they've run into something similar, but you should probably contact SageTV tech support.
Old 04-12-2007, 02:56 PM
rickgillyon's Avatar
Don't know, both my MVPs play audio fine in 6.1.8...
Old 04-15-2007, 01:35 AM
rtengvad rtengvad is offline
It sounds a bit strange this problem. And I guess you are not trying to play protected files since you state that you haven't had this problem before.
I would try to do a clean install of sage on the server. (remember to take a copy of the directory first, because you need your .bin and .bak files)
If that not helps contact support and send them one of the files that will not play.
good luck
rtengvad
Server: Win7 • SageTV v7.1.9 • GA-MA785GM-US2H • Athlon 64 X2 BE-2350 • 2 Gb RAM • 4x 1Tb WD RE-2 GP in RAID5, Adaptec 5405 Raid controller • 2x firewire DVB-C FloppyDTV C/CI, 1x TechnoTrend CT-3650 CI via the LM Smart DVB Recorder plug-in.
Clients: HD300 to a Samsung PS50C7705 (PN50C8000) via a DVDO Edge • HD200 • Placeshifter
Remote: Universal Remote Control MX-980
QAM Channel Maps - List Your Channels Morgan111 SageTV EPG Service 192 01-28-2013 12:23 AM
no audio when playing DVD on MVP johnvk SageTV Beta Test Software 14 12-15-2006 12:42 PM
Playing .ts files on MVP tmiranda SageTV Beta Test Software 0 11-28-2006 07:55 PM
Volume controls when playing music in SageTV 6 Thomas Wischgol SageTV Beta Test Software 3 10-04-2006 01:47 PM
Problem playing music files on the MVP rtengvad SageTV Beta Test Software 10 02-22-2006 04:38 AM
