Old 09-05-2006, 08:15 AM
vorius vorius is offline
Can I set it so I don't need to press OK/select when I enter channel #?
I notice that when I want to jump to a channel by number, I have to type the channel in and the press OK- I really much prefer it when I type in the numbers and then after a short delay it automatically goes, instead of waiting for me to hit OK and then cancels automatically if I dont.
How can I change this?
Old 09-05-2006, 09:46 AM
nielm's Avatar
nielm nielm is offline
Workaround: enter 3 digits: 001, 010, etc...
Old 09-05-2006, 11:47 AM
jbarr's Avatar
jbarr jbarr is offline
You can also configure the number of required digits. So depending on your lineup, if your lineup only has channels under 100 (01-99), then you can set the number of required digits to "2" requiring you to only enter 01, 10, 99, etc.
-Jim Barr
SageTVTips.com
HTPC: AMD ASUS M2N-E Socket AM2 Motherboard; Athlon 64 3200+ Orleans 2.0GHz; 2GB RAM; eVGA 256MB Geforce 7300LE; 1x40GB IDE HDD (OS), 2xSeagate Barracuda 320GB SATA HDD (Recordings); Antec Overture II Case; Windows XP Pro SP2; SageTV v6.5
STV: SageMC
Video sources: Currently, none. I'm using SageTV for Music, Photos, and Video playback.
Old 09-05-2006, 01:27 PM
Excellent, thanks guys!
Old 09-05-2006, 05:22 PM
Ok, I need to ask about how to change the numer of digits required for changing channel from 3 to 2, I have looked around in Detailed Setup and cant seem to locate it
Old 09-05-2006, 05:28 PM
AngelofDeth AngelofDeth is offline
You need to go to Setup Video Sources/YourTunerCard/TunerControl/Remote Control Options. I hope 5.1 fixes it so serial control will work with 3 channel input w/o pushing enter like the IR blaster does, altough ive gotten used to it now.
