Old 11-20-2006, 05:01 PM
traker1001 traker1001 is offline
Placeshifter W/O Install
I would love to see a way for someone to watch videos/tv by just pointing there browser to there setup webite, but without having to download and install the placeshifter client. You know I goto the website and the client installs itself and starts up type of thing.
Old 11-22-2006, 01:10 PM
FidgetyRat's Avatar
FidgetyRat FidgetyRat is offline
I would imagine that would make licensing very difficult.
neilm's webserver stvi does have option to stream videos. Not quite placeshifter but might work.
Server: 2.6Ghz Pentium Dual Core, 2GB RAM. 3x PVR-150, 1.5TB HDD. Geforce 7300GS, Sage 7.0.15
Client: Jetway ION-Top - Dual core ATOM 1.6 & NVIDIA ION
NAS: QNAP TS-419P 3.7TB Raid-5
Special thanks to tmiranda for making my 24h time format dream a reality. See here for more details.
Old 11-22-2006, 01:34 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Placeshifter is meant to be portable. Once you've run the installer, just copy the installation folder onto a flash stick or whatever and you can run it anywhere. The Placeshifter license lives on the server and is per connection, not per installation.
I suppose it wouldn't be too hard to script a web page to download the necessary files from a valid Placeshifter installation to a temp folder on the target machine.
-- Greg
Old 11-22-2006, 02:34 PM
owilsky's Avatar
owilsky owilsky is offline
I think what he means is that there should be a java applet which would be automatically downloaded by the java enabled browser.
So all that you need is a web browser, a java plugin and then every Opera, Firefox or IE with an internet connection could run the placeshifter applet.
Just like UltraVNC when you connect to http://server:5800
Would be indeed fine...
Am I right, traker1001?
Oliver Kötter
Check this thread for importing German TV Data into SageTV
Using SageTV 7.1.9, Java 1.6.0_24 Win7 Home Premium on an
Asus M4N78-AM Mainboard, AMD Athlon II X2 215, 4 GB RAM, 500 GB HDD, 2xTechnoTrend S-2400 as Network Encoder (LM DVB Smart Recorder), ATI Radeon HD 3450 with analog TV-Out on good old CRT TV (100Hz)
My avatar shows the world's best composer!!!
Old 11-22-2006, 06:12 PM
exactly, Place shifter is nice, But they are one step short of being awesome.
I use the wederver stvi, but its no placeshifter.
Old 11-22-2006, 08:02 PM
GKusnick's Avatar
I agree that would be nice, but while you're waiting for that to be implemented, carrying a preinstalled Placeshifter-on-a-stick in your pocket works pretty well as a stopgap.
-- Greg
Old 01-01-2007, 04:02 PM
sojourner753 sojourner753 is offline
Anyone tried running PlaceShifter with a J2ME JVM? I've got a Toshiba e830 that I've been trying to figure our what to do with.
Of course its only 802.11b
Platform: Windows XP Pro; Java: 6.x; SageTV: 6.1.x; Decoders: Nvidia PureVideo Gold;
Machine:Dell Dimension 9200;Processor: Intel® Core™ 2 Duo Processor E6320 (4MB L2 cache,1.86GHz,1066FSB); RAM: 2GB Dual Channel DDR2 SDRAM at 667MHz- 2DIMMs; Graphics Card: 128MB nVidia GeForce 8300 GS; Tuner: Hauppauge WinTV-PVR 500 MCE
Storage: OS/Apps: 160GB (7200RPM) w/DataBurst Cache ; Recordings: Seagate 300GB 7200 RPM SATA; Signal: Comcast Digital Cable with HD Converter;
