Old 01-10-2007, 01:12 PM
harrijay harrijay is offline
QAM ATSC tuning problems
I am currently trying to have sage tune unencrypted QAM channels. I have played with Mythtv and I was able to capture the channels so I know i have the channels available I am just unable to get this to work in Sage. i have seen in some places that this is now supported in version 6, but you have to map your own channels. Some people have also referred to a FRQ file that shows all of the channels that it finds but I never have this file created it just says No Signal when I bring up that tuner. Ther tuner that I am using is AverMedia A180. Anyone have any ideas or suggestions on how to get this working?
Old 01-10-2007, 03:00 PM
hornsounder hornsounder is offline
same problem with dvb-c card
Hello,
thats the same problem i have. i can tune channels with vdr or xine but dont know how to get sage to do it.
Alexander
Old 01-10-2007, 03:26 PM
blade blade is offline
I believe there was undocumented support for some tuners in the linux version of Sage and a few people claimed to have it working at one point, but no one really elaborated on it.
Old 01-10-2007, 05:05 PM
_Demo_ _Demo_ is offline
Send a message via ICQ to _Demo_
Are you selecting adapter0 in the source configuration?
_Demo_
Old 01-10-2007, 06:58 PM
Yes, in my configuration I do have the adaptor0 configured. this is a dump when i run dmesg for my Adaptor if it helps
Linux video capture interface: v1.00
saa7130/34: v4l2 driver version 0.2.14 loaded
ACPI: PCI Interrupt 0000:04:00.0[A] -> GSI 20 (level, low) -> IRQ 233
saa7133[0]: found at 0000:04:00.0, rev: 209, irq: 233, latency: 32, mmio: 0xd7000000
saa7133[0]: subsystem: 1461:1044, board: AVerMedia AVerTVHD MCE A180 [card=75,autodetected]
saa7133[0]: board init: gpio is 10400
saa7133[0]: i2c eeprom 00: 61 14 44 10 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
saa7133[0]: i2c eeprom 10: 00 ff 86 0f ff 20 00 00 00 00 00 00 00 00 00 00
saa7133[0]: i2c eeprom 20: 01 40 01 02 02 ff 01 03 06 ff 01 11 00 00 00 00
saa7133[0]: i2c eeprom 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
saa7133[0]: i2c eeprom 40: ff 64 00 c2 14 16 ff ff 00 00 00 00 00 00 00 00
saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: registered device video0 [v4l2]
saa7133[0]: registered device vbi0
nxt200x: NXT2004 Detected
DVB: registering new adapter (saa7133[0]).
DVB: registering frontend 0 (Nextwave NXT200X VSB/QAM frontend)...
