Old 08-18-2008, 12:51 PM
cybrsage cybrsage is offline
Arcsoft Total Media Theater is currently the only software which effectively plays both HD-DVD and BR discs without having to hack the software.
Anyone know how to integrate this with SageTV?
OOPS! Sorry, did not realize I was in the extender section...the search simply lead me here.
* split to its own topic *
Old 08-18-2008, 03:52 PM
Well, with the stock STV, the easiest way it probably to use nielm's dynamic menu plugin to create a button that launches Arcsoft.
Otherwise I think SageMC has the capability to launch external programs.
Old 08-20-2008, 07:35 AM
Polypro Polypro is offline
That's the best way I've found. This is a new Sub Menu called Watch NetFlix. The external program option adds the TMT and PDVD entries...just point it to the uMCExxx.exe. Just hit Enter on the command line arguments box (you don't need any). I run it on top of Sage (I don't sleep it) and when finished I just hit Menu (closes TMT) and Sage is right there. Works great.
P
STV Import: MovieTimes Movie Listings Import v0.57 Beta aperry SageTV Customizations 670 10-02-2010 12:07 AM
HD Media Extender does not find Server HiDefDon SageTV Media Extender 25 11-10-2008 08:55 AM
Sage Media Library - set the interval for disk checks? Fillian SageTV Software 2 05-23-2008 09:16 PM
PowerDVD and Arcsoft Media Theatre Integration honeybrain SageTV Software 2 02-09-2008 10:25 AM
