Old 09-20-2008, 04:13 PM
DSSavant DSSavant is offline
Moving from Sage Client to Sage Service
Question:
I've been using just SageTV Client for everything; have NOT been using the service. The documents state:
When running SageTV in Service Mode, the SageTV Service uses Sage.properties for its properties, while the SageTV UI uses SageClient.properties.
When not using the Service Mode, the SageTV UI will get its settings from Sage.properties.
I now want to start to use the service so I can turn off the client when I want but in doing so, I will loose all of my many properties already set in Sage.Properties. Can I simply copy the Sage.Properties file to SageClient.Properties to get around this?
Old 09-20-2008, 04:49 PM
GKusnick's Avatar
GKusnick GKusnick is offline
First, to clear up some terminology, if your settings are stored in Sage.properties, then you're not using SageTVClient. You're using SageTV Media Center in application mode (as opposed to service mode). SageTVClient is a separate product for use on network PC clients and always stores its settings in SageClient.properties.
Once you enable service mode, the SageTV icon on your desktop will launch SageTV Media Center in pseudo-client mode. In this mode, as the documentation says, it will take its settings from SageClient.properties.
Nothing bad will happen if you just copy over Sage.properties to SageClient.properties, except that you'll have a lot of extra stuff in there that the pseudo-client doesn't need. You might prefer to run the pseudo-client once to initialize SageClient.properties, and then open both files in Notepad and just copy over the settings you want to keep.
-- Greg
Sage Client Questions camus SageTV Software 15 05-14-2012 07:00 AM
Wired MVP Client not working with Sage but does with MediaMVP version 3.2 hankjones SageTV Media Extender 29 03-13-2008 05:09 PM
Sage server upgrade to Xeon, client help. mleonard Hardware Support 1 07-08-2007 10:45 AM
Use full-install Sage as client? elaw SageTV Software 11 01-27-2006 03:09 PM
Sage client network routing etk29321 SageTV Software 4 12-07-2005 02:31 PM
