Old 06-25-2009, 03:48 AM
ainakea ainakea is offline
How to enter 4 digit channel via keyboard
I have just installed version 6.5.9.204 and am using USB-UIRT IR blaster to change channels on my Scientific Atlanta Explorer 3250HD box. Everything seems to be working except that when using the keyboard to enter a channel number I can only enter 3 digits.....if I use the program guide for a 4 digit channel everything changes fine. Can someone tell me how to get the keyboard to recognize 4 digit channel numbers? Sorry if this is a dumb question...but thanks in advance for your help.
Bill
Old 06-25-2009, 07:12 AM
Either use a newer beta for its better automatic max-length channel number determination, or go to Detailed Setup -> Customize -> Channel Entry Options & set Max Channel Digits to 4.
Can you enter a 3 digit or 4 digit channel ? squeed SageTV Software 1 10-20-2008 09:50 PM
channel change without enter? lcddream SageTV Software 1 12-28-2006 11:37 PM
Unable to enter double digit channels sabre SageTV Software 6 11-15-2005 01:20 PM
Remote tuning problem - USB UIRT drops first digit of 3-digit channels swad Hardware Support 1 10-07-2005 12:37 PM
forcing 3 digit channel change alonpb SageTV Beta Test Software 2 04-20-2004 08:56 PM
