Old 09-21-2021, 05:49 PM
tvmaster2's Avatar
Having trouble playing a Blu-ray rip
Trying to play a blu-ray ripped film, that was done in h.264 mpeg 4
File plays and sounds great, but I'm seeing NO timing info, nor can you FF or RW.
The file plays in VLC, Media Player, Plex, etc, with proper timing info, chapters and sync.
3.5gb file, and the drive it's on is NTFS.
What could be causing Sage Server to barf on the timing info?
I've recoded using a different, Handbrake preset - same thing: plays everywhere with timing info EXCEPT Sage.
Ideas?
Here's the codec info
Old 09-21-2021, 08:10 PM
CptKirk CptKirk is offline
I reported the same in another thread. Hoping Josh would see and take a look.
https://forums.sagetv.com/forums/showthread.php?t=66769
SageTV running on: Win7 SP1 64 Pro
SageTV 9.2.5.936 (32 bit)
Java 1.8.0 301 (32 bit)
OpenDCT 0.5.32 (32 bit) (Comcast Music channels set to FFmpeg)
Clients: HD300 (x2)
HDHR3-CC Prime 20190621 (Comcast CableCard) - 3 Tuners
Hauppauge 1950 STB SD (USB-UIRT Zone 1)
Hauppauge 1950 STB SD (USB-UIRT Zone 2)
Old 09-21-2021, 10:21 PM
tvmaster2's Avatar
Cool, Iíll have a look. File plays EVERYWHERE, properly, except within Sage Server
Old 09-22-2021, 12:19 PM
tvmaster2's Avatar
OK, just recoded the file AGAIN in Handbrake, this time using Matroska h.264 1080p preset. Also set the 5.1 audio AAC to Auto Passthru.
Bingo - time info is back, sync is correct, and the file now displays and plays properly in Sage.
So it's either a Handbrake preset setting, or a Sage limitation of a newer, Handbrake protocol?
Either way - that's my result today
Trouble with FX GTwannabe Hardware Support 4 11-21-2013 04:43 PM
having trouble playing back an mpeg-1 rosemary SageTV Software 3 02-13-2010 07:29 PM
SageTV Client Having Trouble Playing back Live TV shatter SageTV Software 0 08-12-2009 12:12 AM
QAM trouble uberliberal Hardware Support 3 02-10-2008 10:52 PM
Trouble Playing Audio Files jovac SageTV Software 4 09-01-2005 12:42 PM
