Old 01-02-2006, 01:08 AM
DavidFeinzeig DavidFeinzeig is offline
Setting favorites to only record HD airings
Is there any way to set a favorite to record only HD airings? If not, I think it'd be nice to have.
Old 01-02-2006, 09:25 AM
Limit the Favorite to a digital channel; other than that, you can't say "HD only".
Old 01-03-2006, 07:27 AM
AMCooper63 AMCooper63 is offline
I don't want HD only, I'd just like to be able to set the preference to HD. I currenlty only have one HD tuner. Once in a while, I have a conflict where I have more than one HD show at the same time. I wouldn't want to miss one just because the tuner was busy. I have one news program that records both the HD version and the analog version. Other times the Digital tuner isn't being used and my HD available programs aren't scheduled to the Digital tuner. They record on the analog tuner. So all I really want is a way to prefer the digital tuner when it's available.
Old 01-03-2006, 08:35 AM
ben_95sl1 ben_95sl1 is offline
how bout making multiple favourites for the same show limited to different channels (one limited to HD channel higher priority then one for ANY channel)....
a weird way to do it, but should work.
Server: XP SP3, X2 BE 5000+, WD 1.5TB x 2, PVR150 & HD-PVR, USB-UIRT
Clients: HD300, HD100 x 2, Media MVP in a box somewhere
Old 01-03-2006, 01:22 PM
TakeFlight's Avatar
TakeFlight TakeFlight is offline
To follow up on the previous post. For example, I have Letterman, Leno, Conan and Ferguson set to record using my two analog tuners every night. In addition, I also have Letterman and Conan recording in HD using my Motorola DCT-6200 connected via firewire. So, I'm recording Letterman and Conan both in SD and HD. The reason I'm doing that is simply because I had the Favorites that record via the analog tuners set up before I had HD recording capability and I've never turned it off. I've got plenty of hard drive space so it's no problem. In case their is a glitch in the HD recording (which basically never happens but I guess I don't trust it as much as the good old analog tuners cards) I have the SD recording to fall back on.
Pegasus - SageTV/HomeSeer Server: Core2Duo 1.8GHz, 1GB, 1.5TB RAID5, 2.25TB RAID5, Radeon X1050, (2) Hauppauge PVR250 (only used for security cameras now), SiliconDust HDHomeRun, Hauppauge HD-PVR, WinXP Pro
Prometheus - SageTV Client: Core2Duo 2.66GHz, 1GB, 500GB, GeForce 8400GS, WinXP Pro, 848x480 to InFocus SP4805 projector on a 78" screen
HD Theater (HD200) connected via HDMI to Panasonic TH-42PX60U 42" plasma
web server plugin | 2 MediaMVP Extenders | FiOS TV
Old 06-03-2009, 06:37 AM
Patrick25 Patrick25 is offline
I have the same setup but Sage only records one instance of a given episode. If it's being taped in SD, it won't tape in HD and vice versa.
Old 06-03-2009, 07:33 AM
Just set the merit of your digital tuner(s) higher than the analog ones. Then Sage will use the digital tuner(s) first and the analog ones will be fallback.
Also it's my understanding that Sage will prefer an HD airing over an SD one and record the HD one. But that requires that the guide data be accurate and mark the HD one as HD.
