Old 02-06-2007, 09:11 AM
simonen simonen is offline
2 EPG for 1 video source
I am tryng to determine if it is possible to map 2 EPG's to one video source. I am using the HD Homerun with QAM and there is one channel called Universal HD which is not in the zap2it line up with my digital cable system even though the channel exists. The channel is present if I use satellite EPG, but then the rest of my channels are for a different city, so that won't work.
What I would like to do is use the correct EPG for the channels I receive and for the one there is no EPG for, use a different EPG for that 1 channel. Is this possible?
Old 02-06-2007, 10:22 AM
Since the channel is available on another lineup, try this: go to the Zap2It site, find the station ID for that channel (usually in the url seen when you click on the channel), then add the channel in Channel Setup.
Old 02-07-2007, 08:51 AM
Worked like a charm! Thanks...
