Old 09-19-2008, 07:52 PM
getstarted getstarted is offline
sagetv is not working after changing to MCE
I bought MCE remote, and changed the settings to use MCE. From there, It keep coming to "Main Menu", cannot change to any thing. I have to use ctrl+Alt+Del, and close the sagetv.
1) How do I change this setting to make sagetv work?
2) Probably MCE remote driver is not installed in my PC, where and how can i download the MCE driver? I am using Vista 64bit OS.
Old 09-20-2008, 11:36 AM
bhyman1 bhyman1 is offline
Which specific version of Vista are you using? Premium, Ultimate, etc, etc...
Old 09-20-2008, 03:57 PM
Ultimate; Sage was working fine. It started behaving like this only after I changed to MCE remote. Is there any way to configure manually through property files to revert that change?
And MCE remote has worked fine for Windows Media Center; i was able to control windows media center.
Old 09-21-2008, 06:21 AM
There's a few services related to Vista Media Center you need to stop so Vista will stop capturing the MCE remote commands and keep them from getting to Sage.
Do a quick forum search here for the right services to stop.
Old 09-21-2008, 07:53 AM
I stopped after the fact. But now i am not able to change any settings on sagetv, as it keep coming to main menu. First i need to revert that change somehow through configuration files.. Any help?
I submitted ticket to sagetv yesterday, no response yet
Edit: i uninstalled the software and re-install. still it keep doing the same. Struck for two days.
MCE Remote and blaster EricandLorrie Hardware Support 4 10-01-2008 05:36 PM
Does anyone have a XP MCE networked to a Vista system? carlgar The SageTV Community 0 05-21-2008 06:46 AM
Thinking of converting from XP MCE to Sage - a few questions? wayner General Discussion 9 04-11-2008 08:29 AM
Disable or uninstall MCE in Vista? visiontim General Discussion 9 12-29-2007 09:28 PM
MCE2005 = Sage 2.0 killer? rotaryracer General Discussion 45 10-27-2004 06:50 PM
