Old 09-27-2008, 09:13 AM
getstarted getstarted is offline
Why is the remote setup is so confusing and difficult to make it work?
I still couldnot setup my remote control.
I have HVR-1600 card, it came with 45 button remote. I also bought "Black Multimedia MCE Remote Controller with USB IR Receiver". And I am using Microsoft wireless keyboard and mouse.
Now my problems are:
  1. Whatever I do, sage is not responding to hauppauge remote at all
  2. Microsoft MCE remote is responding for few commands, probably just "OK" is working.
  3. Currently I chose Hauppage as remote, but still sage is responding to only MCE remote(few commands)
  4. When I select MCE as a remote in sagetv, I couldn't go anywhere in the sage menu. It keeps coming back to main menu. If i disconnect the wireless keyboard receiver, then it is responding to few buttons in MCE remote.
  5. When I try to change channels through Sage Program guide, it only works few times. What are the best channel delay options?
Please suggest the simple way to configure either one of these remotes. Once i setup atleast one remote, then i will configure harmony 880 remote.
Yes, I read so many threads about MCE, hauppauge remote setup in this forum. but got confused for so many alternatives and not sure which is latest and which one is outdated.
I tried few of the suggestions, and didnt work.
My environment:
SageTV (latest version)
HVR-1600 with hauppauge 45 button remote
Windows MCE remote
Dishnetwork 311 receiver
Vista Ultimate 64 bit
AMD 6000+ processor
4GB RAM
Thank you for your help.
Old 09-27-2008, 09:49 AM
My environment:
Windows MCE remote
AMD 6000+ processor
4GB RAM
I've never used the hauppauge remote for controlling Sage from a server or full client (obviously thru an MediaMVP) so I can't comment on that. I had no problems setting up a true windows MCE remote on my clients in the past other than finding and installing the drivers. If you are using a true MCE remote (and not just a remote that calls itself an MCE remote), then its just a matter of selecting the MCE Remote option within the configuration setup. NOW, there could be an issue with 64bit Vista that may not work with the MCE remotes....you may want to google that. All of my experiences have been with Windows XP Pro....(can't bring myself to make the jump).
Old 09-27-2008, 10:11 AM
Here is the remote that I bought.
http://cgi.ebay.com/HTPC-MCE-Wireles...742.m153.l1262
Edit: i just noticed that my audio is not working for any of my videos. it is working fine on windows media center.
Old 09-27-2008, 10:20 AM
heffe2001's Avatar
You'll probably have to use something like HIP or girder to get that remote working, I don't think it's a real MCE remote. With one of those (a real MCE remote), it'll just work (I used to use these before I bought my HD extenders, they work great with sage). Real MCE remotes have a button on it that looks like the Windows logo, usually in green. What you have is a knock-off, generic PC remote.
Old 09-28-2008, 07:25 AM
Is HIP free? i spent too much on this project.. ran out of money.. where can i download it?
Old 09-28-2008, 01:11 PM
If the Hauppauge remote is really a Hauppauge remote instead of their MCE type of remote, then see this FAQ and/or my sig lines:
How do I use the Hauppauge remote to control SageTV? When I press a button, nothing happens.
