Old 02-20-2006, 10:39 AM
tmiranda's Avatar
tmiranda tmiranda is offline
How to move recorded shows into Archived Recordings?
I'm using the latest version of Sage and have enabled the super secret Malore menus (5309). Problem is now when I look at the info screen for recorded shows there is no option to Archive it. If I disable the Malore menus the option to Archive returns.
How can I Archive without disabling the Malore menus?
Old 02-20-2006, 11:21 AM
If I understand the problem correctly, then in the malore menu options dialog, set Smart Select to "Display Options".
Old 02-20-2006, 12:00 PM
tmiranda's Avatar
That did it, thanks much.
