Old 07-12-2007, 12:54 PM
jmann jmann is offline
When TV is live, sagetvtranscoder.exe fails to start
So, let me explain the symptoms. TV is being recorded, and I am trying to watch that live broadcast over placeshifter at around 300K. At the same time, commercial detection is running (show analyzer). I can usually skip around that live program a few times, but eventually after one skip the placeshifter client stops getting streamed video (the GUI is fine).
Not if I stop the stream and try to restart it, the same failure persists (this works if the program is not live), and the video stream does not start. When I look at what is happening in the server, I can see sagetvtranscoder.exe start up and immediately close in the task manager. So once this hickup happens, I cannot watch the program, even if I try to start streaming it at a different point.
I believe this problem began when I upgraded to 6.1.9. Prior to this, I still had programs fail when I skipped around, but they immediately started up again when I stopped and started the stream again.
has anyone else seen this behavior, and if so what is the solution?
Old 07-18-2007, 12:24 PM
Anyone?
Old 07-23-2007, 12:23 PM
anyone?
Old 10-04-2007, 12:01 PM
I'm being ignored
I've even upgraded to the newest 6.2 version. Someone must have a suggestion or seen this behavior before.
Old 10-04-2007, 12:38 PM
If you turn off all customizations, including commercial skip/detection, and you still have the problem, then contact SageTV support.
Live TV show position with multiple clients troll5501 SageTV Software 2 02-24-2008 09:34 PM
HD audio stuttering only while watching live tv ripple SageTV Software 0 09-09-2006 06:02 PM
Newbie Question: Live TV jbarr SageTV Software 1 08-30-2006 10:01 AM
What happens to Live TV after sched recording starts? ripple SageTV Software 1 11-04-2005 04:31 PM
cannot start live TV. Ryokurin SageTV Beta Test Software 8 02-08-2005 11:52 AM
