Old 01-11-2011, 10:27 AM
Ted@TNT's Avatar
Ted@TNT Ted@TNT is offline
Send a message via AIM to Ted@TNT
Plugin to move Archived shows Movie directory
Maybe it already exists, but I can't seem to find in using scrolling through the plugins or searching here.
Sometimes, when I record a movie, I want to keep and view it a while. However, I'd rather not have it in the "Recordings" directory or located on the "Recordings" drive. I'd like to be able to save it as a Movie so that it will get moved to the "Movies" director (on a server on the network) and show up in the "Movies" listings like my other DVD's and movies.
Is there a way to do this?
Ted
W7 64-bit, SageTV V7, Phoenix2 Asus P5W DH-Deluxe Motherboard, Core 2 Quad, 12 GB DDR2, 250 GB OS, 2 TB Recordings, 6 TB Movies (holding DVD library), nVidia 285, HD PVR 1212 x2, HDHR x2, Zalmann HD160XT case, Harmony 890pro Remote. Pioneer 50" KURO Plasma, Pioneer Elite 7.1 surround A/V receiver, Energy & Paradigm speakers.
Old 01-11-2011, 10:55 AM
vividweb vividweb is offline
BMT (Batch Metadata Tools) can change where a recording shows up either in the Videos area or the Recordings area. It won't move the actaul location of the file.
Sage Server: i5-2500K 8 GB DDR, 6000gb HDD, 4xHD-PVR < 4xBell 6141, Win7 x64
Client 1: HD-200, Panasonic 42PX75
Client 2: HD-300, Samsung LCD
Client 3: HD-300, Samsung PN50C550
Client 4: MS Surface Pro
Old 01-11-2011, 04:42 PM
Spectrum Spectrum is offline
You could automate moving movies with SJQ. I had it set up on V3, but haven't updated my mover script for V4 yet. If you already have V3 of SJQ installed I still have a rule and a client script you can modify and make work, but if you don't already have V3 installed you would need to figure out how to script the move using groovy unless someone else has already done so.
[PLUGIN] Move Imported TV Shows to SageTV Recordings Fuzzy SageTV v7 Customizations 32 02-26-2011 03:22 PM
Record to one directory.. move shows to another for viewing jasondragon SageTV Software 8 03-08-2009 08:59 AM
at root menu of DVD movie, can move cursor, but can't select (play movie)?? mattress SageTV Software 1 09-04-2006 11:15 AM
Don't want ripped versions of shows showing up in Archived Shows menu squee SageTV Software 1 07-03-2006 09:27 PM
How to move recorded shows into Archived Recordings? tmiranda SageTV Software 2 02-20-2006 12:00 PM
