Old 12-21-2011, 05:24 AM
jjstok jjstok is offline
Failing converted AVIs: Move Imported TV Shows to SageTV Recordings
Lost my server and had to rebuild everything and it really sucked. I was able to recover most of my TV recordings. As I add their containing dirs, it seems as though the only recordings that get imported back into the All Recordings are the ones which were not converted. Most or all of my conversions are now AVIs which seem to be which are not importing.
What can I do to get these AVIs back into the All Recordings menu again?
I've seen other recomendations (BMT stuff...) for similar problems attempting to fix them one at a time but I have hundreds so that is not easily workable.
I believe what has been working so far is due to Fuzzy's plugin but it doesn't seem to help with the AVIs.
Anyone please?
Dell PE 2800 - Dual Xeon - 2gb RAM - Windows 2003 sp2 - 2 Video Cards: Hauppauge WINTV HVR 1600 digital
Old 12-21-2011, 05:47 AM
Look to see if they ended up in Archived recordings. If they did you can un-archive so they show up in all recordings.
Old 12-21-2011, 08:20 AM
Most if not all I have looked at have been archived. It doesn't make a difference though.
Old 12-21-2011, 03:40 PM
Also the previous TV Recordings which reside in Video Recording directories are getting imported inidividually into the Videos import directory... I have two specific locations for video imports and these files are not even in the same partition... wth?!?!?
[PLUGIN] Move Imported TV Shows to SageTV Recordings Fuzzy SageTV v7 Customizations 32 02-26-2011 03:22 PM
It's adding a converted file into my SageTV Recordings? agdm619 SageTV Software 1 12-21-2009 10:55 PM
SageTV Recordings move around in teh list MickBurke SageTV Software 2 03-10-2009 01:15 PM
How to move recorded shows into Archived Recordings? tmiranda SageTV Software 2 02-20-2006 12:00 PM
How to move shows from the archive back to SageTV Recordings Opus4 SageTV Software 1 08-24-2004 07:09 PM
